Constant power with fuse.
Old Mar 30, 2011 | 11:18 AM
SilverJ's Avatar
I would like to add a constant power wire for my sirius stiletto. I can tap into the existing aux in and run the antenna wire under the dash I think to the windshield. I would prefer not to have to open up the dash. What would be the easiest way to accomplish this ?
Old Mar 30, 2011 | 11:21 AM
jda123's Avatar
Dogmatic Dinosaur
If you wanna go up high with it, there is constant power in the overhead console for the map lights and HFL. You could tap into that.
Old Mar 30, 2011 | 01:40 PM
SilverJ's Avatar
not even sure how I would do that...I was hoping for something maybe running from the fusebox.
Old Mar 30, 2011 | 11:20 PM
csmeance's Avatar
The seat motor for the driver has constant power if I remember correctly so when you unlock the car you can still move the seat around.
Old Mar 31, 2011 | 08:40 AM
jda123's Avatar
Dogmatic Dinosaur
Find a 12v + with the car off and use an inline wire splice connector.
You could also use an add-a-fuse in the fuse box. The one for the HFL and map lights is on all the time - forgot which one it is, though.
Old Mar 31, 2011 | 10:06 AM
invalidalias's Avatar
add a circuit
whether its the interior light circuit or seats, find 'add a circuit' at orielly. Really cool fuse with build in splice. You have to see it to understand it. You can tap into 'always hot' or 'hot with key on' circuits.
Old Apr 1, 2011 | 10:56 AM
SilverJ's Avatar
thansk I will check it out.
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
DerrickW
Nov 15, 2015 05:52 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
