Constant +12V
Old Feb 16, 2005 | 06:53 PM
6mtV6's Avatar
I6
Constant +12V
Are there any other constant +12V wires besides the one in the ignition switch harness?
Old Feb 17, 2005 | 11:01 AM
I-MOD's Avatar
2018 TLX A-SPEC
Left kick panel should be in there with the other feed lines to the ignition. Solid white if i remember correctly. Heavy gauge wires
D.
Old Feb 17, 2005 | 11:29 AM
Bxscig's Avatar
Power seats are always +12Vs, dome lighting as well
Old Feb 17, 2005 | 06:00 PM
6mtV6's Avatar
I6
D.
That's the one I was talking about.
Is it possible to buy a "create a circuit" and tap into a unused slot on the fuse box? Is there a unused slot that has a constant +12V?
Old Feb 19, 2005 | 12:28 AM
6mtV6's Avatar
I6
I know for the CL, Acura provides 4 different connector points. They are numbered 24-27. Each one has power under different conditions. Such as power on all the time, power on when engine is on, power on in accessory mode. Does the TL have this also?
Old Feb 19, 2005 | 10:07 AM
DanL's Avatar
Not sure why not. Even if you can't use the 'create a circuit' in an unused slot, you can use a 'create a line' in a used slot as long as you don't need more than an additional 10 amps.
rockyboy
Aug 4, 2024 10:35 AM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
SidhuSaaB
May 30, 2020 12:40 AM
DerrickW
Nov 15, 2015 05:52 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
