Connecting a Galaxy 3 to the bluetooth help!
hello everyone im new to this forum
, i signed up right when i got my acura and i love it
, but anyways i was wondering if anyone that has a galaxy s3 or some other new phone ever got their phone to connect to the hands free link, i can get all the way to where it searches for the phone, i have my phones bluetooth on and on discoverable mode and i search for the car on the phone and they never can find each other
, the can without a problem connect to my old iphone 4 but not my galaxy. any help would be much appreciated!
Usually I have to set the phone to discoverable, pair on the HFL, and then click the HFL in the bluetooth devices on the phone. It doesn't normally automatically pair the first time. You have to select it in the list.
I had zero issues setting mine up following the directions in the owners manual. Works great. I know sometimes different carriers set the phones up differently, mine is Verizon.
Took me 1 minute to set up my S3. Try starting the pairing process with your bluetooth turned off on your phone and then turn it on when the HFL starts searching.
2) hit the car hfl button and say "phone setup"
3) hit the car hfl button and say "pair"
4) Follow the prompts and enter your pin in the HFL
5) When it tells you to make your phone discoverable, goto your phone bluetooth settings and turn on discovery.
6) In a few seconds the HFL should show up in the list of bluetooth devices on your phone. Select it.
7)The car will say it connected and tell you to enter your pin. Do so on the phone.
8) Car will prompt for a name. (or maybe this was earlier?) give it one.
You should be paired now. I switch roms on my phone a lot and have to go through the whole pairing thing all the time.
1) make sure the phone bluetooth is on
I have tried to pair my S3 multiple times in many different orders and each time my HFL gets stuck in "Pair" mode forcing me to disconnect the battery to get control of my radio again. The phone recognizes the HFL and prompts me to enter my PIN which I have done, but the HFL never connects.
I had no problem whatsoever pairing my BlackBerry so I have no clue what the problem is. At this point I have just said eff it and use the speaker phone on the S3. I would love to get the HFL operational with the phone though so any help would be appreciated.
Hmmm strange so many are having issues, my mom's S3 through VZW is also linked in my car when she borrow my car.
Her's linked up no problem when I set it up and she is running the latest firmware update, no roms at all.
Maybe a bluetooth module?
just got my gs3 today and set it up w/o issues, here is what I did:
5) When it tells you to make your phone discoverable, goto your phone bluetooth settings and turn on visible mode then click scan.
6) In a few seconds the HFL should show up as a mac address first. Select it.
7)enter the same pin you setup in hfl on the phone.
My S3 from Verizon paired perfectly on the 1st shot, and so did the replacement unit I got after I dropped mine and broke the screen.
There is after all, a handsfreelink customer service/tech support # you can call if you're still having problems, 1.888.528.7876.
MetalGearTypeS
Aug 29, 2016 08:28 PM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
