Clearing HFL Problem
Old Aug 21, 2004 | 07:57 PM
Tedanddenise's Avatar
Perhaps it's me, but, I can't seem to clear the memory or delete a cell phone on my TL's HFL.. I followed the instructions to the "T" several times and get into this endless loop. Has anyone else tried it - perhaps it's just a software problem in Honda's logic? I changed phones from the Nokia 6280 to the T637 and wanted to clear out the 6820, btw. Also, one has to do this before selling the car or all of your phone numbers go with it (unless you individually delete each one).
Old Aug 22, 2004 | 07:20 AM
smoore's Avatar
I have had no problems deleting phones using the instructions in the manual. In fact, you can follow HFL help and it will pretty much direct how to delete.
The phone numbers are not tied to the phone. For example, I have input about 15 numbers and my wife a similar number. Regardless of which of our two phones are pairee, we can access any of the numbers. It appears that the numbers are input into the car's memory and this is in no way tied to the phone. So if you want to delete phone numbers you have to do it using the HFL and I believe that each number must be manually deleted.
Old Aug 22, 2004 | 08:50 AM
żGotJazz?'s Avatar
Cesspool of Knowledge
TedAndDenise- If you are really desperate to clear out all the phone numbers and settings, have you tried pulling the red (+) battery cable off for a few minutes yet? That may do the trick, but I hope not. I sure hope that the HFL phone information is written into Non-Volatile memory to make sure that the information is more permanent.
If you are going to try pulling the battery cable for a few minutes, you may need to have the Acura's radio security activation code to unlock your radio.
Old Aug 22, 2004 | 02:30 PM
Dirac's Avatar
Someone in another thread experienced the lock-ups, and said that when they removed the battery to restart the computer, they had to reprogram their phone numbers. Don't know about the actual phone pairing, though.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Markbby06
Sep 17, 2015 02:30 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
