Clean custom sub for TL!
Old Jul 7, 2010 | 09:46 AM
saintsfan's Avatar
Finally got my sound completed couple weeks ago. I have 08 TL type S with the factory ELS sound system. I upgraded the 2 front doors and rear deck with Infinity Reference 6032si. Then added a L5 Kicker Solo Baric with custom enclosure on a Hifonics 600watts mono block amp. Also Dynamat the trunk lid and top part of the trunk. Gotta say this system sounds great and i am very happy with it.
Old Jul 7, 2010 | 09:49 AM
saintsfan's Avatar
http://i1005.photobucket.com/albums/...wImagesub1.jpg
http://i1005.photobucket.com/albums/...wImagesub2.jpg
Old Jul 7, 2010 | 09:52 AM
Looks good!
I bet it sounds great!
Do you have the box band-passed through the armrest? or is it a sealed box?
Old Jul 7, 2010 | 10:02 AM
MadeMan716's Avatar
Now that's nice. It doesn't look like you gave up any trunk room.
Old Jul 7, 2010 | 10:27 AM
saintsfan's Avatar
Looks good!
Thanks!! it sounds really good, clean highs and tight bass. The box is sealed, it has a rear and front wings to fill all the space to fit perfect in the trunk.
Old Jul 7, 2010 | 10:28 AM
saintsfan's Avatar
You are right, still have good bit of the trunk to use!!
Old Jul 7, 2010 | 12:28 PM
Andruha88's Avatar
SpeedDemon
Were these speakers a direct drop in? Did they sound mich better than stock? Louder?
Old Jul 7, 2010 | 01:57 PM
saintsfan's Avatar
They rear deck were direct drop in, the front i had to cut the plastic in the rear of the mounting hole. Not very hard to do, and online i only paid 69.99 a pair which are well worth it!!!!! They sound much better, espically if you gonna put a sub!! Without a sub, don't know if i would just upgrade those speakers. Just cause it would be to much highs IMO.
Old Jul 8, 2010 | 07:01 AM
JackSampson's Avatar
Looks good man. I have the same car just 07. I just installed a sub and upgraded the front speakers with Polk DB651s. It sounds better but I think I need to add another app for the cabin speakers.
Old Jul 8, 2010 | 09:00 AM
saintsfan's Avatar
Thanks man! Guess it all depends on what size sub and how many!! If i put a amp on my cabin speakers i would need more bass, ill probally change center channel spaeaker next and ill be done with my sound!!
Old Jul 9, 2010 | 04:46 PM
xxkevo's Avatar
'06 NBP TL
did you have to use a spacer or bracket for the rear? I'm installing mine soon and i know the mounting holes dont line up correct? and tips?
Old Jul 9, 2010 | 04:52 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Nice.
Old Jul 12, 2010 | 07:55 AM
Wasp187's Avatar
4th Gear
Looks really good. I just purchased an 07 6 speed and the sub is blown. How hard is it to add an aftermarket sub and amp to the stock stereo? details?
Old Jul 12, 2010 | 08:10 AM
^its just like any other sub/amp install.... except you add an LOC. (line out converter)
Old Jul 12, 2010 | 09:24 AM
saintsfan's Avatar
I used the mounting ring that came with the infinity speaker and drilled new holes where need for it to fit properly, actually in the front did the same!!
Old Jul 12, 2010 | 09:26 AM
saintsfan's Avatar
I actually let a Local Audio place install the amp wire kit and had the wires run to the trunk. I did the rest!!
Old Jul 12, 2010 | 10:19 AM
It looks like you lost a little bit of depth in the trunk with the mounting board. Is it attached to anything or does it stay put because it is attached the sub box? I was about to do smomething similar with my set up but want to keep the passthrough and as much space as possible. I am going to build a fiberglass sub box for the rear drivers side area soon.
Old Jul 12, 2010 | 11:08 AM
saintsfan's Avatar
Yes u do lose some depth, but i can care less about my trunk space!! It has a rear mounting board and front mounting board that are all connected together, you can't remove it!! The reason for it is the box is built to slide into trunk and the front and rear mounting boards are their to make it fit perfectly!! I ordered the box, it was built and shipped to me. I was very pleased with how it looks, and the sound is great. Let us know who that fiberglass box comes out if you decide to build it!
Old Jul 12, 2010 | 03:03 PM
dbqkqh's Avatar
Hey nice setup.
Several Questions:
1) I'm assuming when you say Stock ELS System, you meant the HU right?
2) Any additional electrical upgrade? Another battery, or alternator? Or even a capacitor?
3) What are the specs on the L5
4) I guess depending on the answer from #2, if you do not have any electrical upgrade, how is the L5 and the Hifonics running? Have you noticed any dimming in lights and such?
Sorry for the questions, but I too was about to invest in Kickers but I thought that the stock electrical wouldn't be enough to support the system, so I went with a budget friendly alternative, The Boston Acoustics G212SS @ 300 watts RMS powered by a Kenwood Amp.
Thanks for the reply!
Ooh, also, video would be nice
Old Jul 12, 2010 | 03:15 PM
Originally Posted by dbqkqh
Hey nice setup.
Several Questions:
1) I'm assuming when you say Stock ELS System, you meant the HU right? yes, the stock head unit.
2) Any additional electrical upgrade? Another battery, or alternator? Or even a capacitor? I dont think he has anything upgraded or else he would have disclosed this information.
From kickers website....
Size (IN.,CM) 10, 25.4 Impedance (OHMS) 2 or 4 DVC Max Rec Amplifier Power (WATTS PEAK/RMS)* 900/450 Sensitivity (dB 1w/1m) 86.3 Frequency Response (Hz) 24-100 Mounting Depth (IN.,CM) 6-3/16, 15.7 Mounting Cutout, Square (IN.,CM) 9-5/16, 23.7 Min Rec Sealed Box Volume (CU. FT., Liters) .66, 18.7 Max Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3 Min Rec Vented Box Volume (CU. Ft., Liters)** 1.25, 35.4 Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.8
Old Jul 12, 2010 | 11:37 PM
saintsfan's Avatar
Perfectly answered Just in Space!
question 4- No electrical upgrade needed, its just a 4gauge amp wiring kit going to the battery!! No problems with lights diming at all. Like i said i did everything myself except the amp wiring, i wanted to pay to get that done and make sure all the proper stuff was used. My subwoofer control even still controlls my L5!!
Old Jul 14, 2010 | 03:21 AM
Keanu's mrs. T's Avatar
Bella Nova
very nice indeed, @ what airspace did you put that L5 in?
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
AcuraKidd
Sep 25, 2015 11:18 PM
