Changing temperature faster
I know this probably doesn't belong here. But I can't find info on this ANYWHERE. I don't have my users manual and I don't know where to look anyways. And it's a very stupid question. But is there a way to quickly change the temperature on your dash from high to low or vice versa? I find pressing and holding to be slower than just hitting the button 30 times fast. But it's a little inconvenient. Sorry for dumb question!
Edit: sorry forgot car info. Acura tl 2005 with no navigation
9th Gear
In my case i use voice commander.
You can say "temperature 72" than your navigation will repeat your order.
Also you can change the fan speed by your order.
Hope this will help you.
9th Gear
Set-up Commands (set-up screen)
Brightness up
Brightness down
Volume up
Volume down
Volume off
Display off
Display day
Display night
Display auto
Climate Control Commands (map screen or climate control screen)
Climate control automatic/auto
Climate control off
Climate control fresh air
Climate control recirculate
Climate control defrost
Climate control defrost off
Climate control dash/near
Climate control dash/vent
Climate control floor
Climate control dash and floor/Bi-level
Climate control floor and defrost
Air conditioner on/AC on
Air conditioner off/AC off
Rear defrost
Rear defrost off
Fan speed 1
Fan speed 2
Fan speed 3
Fan speed 4
Fan speed 5
Temperature Commands (map screen or climate control screen)
Temperature # degress (57-87 ºF)
Temperature up
Temperature down
Passenger Temperature # degrees
CD Commands (map screen or CD or radio screen)
CD Play
(CD mode only)
CD play disc # (1-6)
CD play track # (1-30 only)
CD skip forward
CD skip backward/back
CD play next disk
CD play previous disc
CD track random (within one CD only)
CD track repeat
CD disc repeat
CD normal play (cancels random, repeat, etc.)
Radio Commands (map screen or CD or radio screen)
Radio Play
Radio Off
Radio select AM
Radio select FM1
Radio select FM2
Radio # AM (# frequency)
Radio # FM (# frequency)
Radio seek
Radio seek down
Radio auto select (will reset previous presets)
I also found these commanders on Acurazine.
G
Brightness up
Brightness down
Volume up
Volume down
Volume off
Display off
Display day
Display night
Display auto
Climate control off
Rear defrost
Rear defrost off
Fan speed 1
Fan speed 2
Fan speed 3
Fan speed 4
Fan speed 5
Temperature up
Temperature down
CD Play
(CD mode only)
CD skip forward
CD play next disk
CD track repeat
CD disc repeat
Radio Play
Radio Off
Radio select AM
Radio select FM1
Radio select FM2
Radio seek
Radio seek down
G
justnspace (05-08-2013)
rockyboy
08-04-2024 10:35 AM
