Cellular phone book
Cellular phone book
Have linked my cell phone to the HFL and it works great. My Cellular Phonebook is grayed out, how can I turn this function on. Would like to import my cell phonebook. Have a Sony and this function can be imported. Reviewed my manual and was no help. 07 TL_Type S
THanks
THanks
LIST/RAMEN/WING MAHSTA 짱
I have the same problem with my BlackBerry Curve 8310. There is a certain Acura site (I don't remember the site) which gives the exact phone models, and the extent of the compatibility. Some phones won't sync, some phones will link to the HFL but won't import the phonebook to the HFL (as in our cases), and some phones are fully compatible, including the ability to import your cell phone's phonebook to the HFL.
If there is a way, I'd definitely like to figure out how to import my phonebook as well.
The Acura site is not up to date, I have the new Sony Ericsson Z750a which can import the phone book. To do this I would like send to the nav screen. I need to open the cellular phonebook, but my display shows they are grayed out. The manual said this will happen is the HFL is not linked, but mine is linked. So if I can find out how to turn on the celluar phonebook, import will happed.
Originally Posted by LoveMyTL-S
Originally Posted by nalek
Did you unplug your XM Module for an ipod adapter (Dice, USASpec, etc...)
If so, all HFL stuff on the Navi will gray out (including the "call" button)
Appreciate your reply.
for the phone book uploader just keep trying from the nav... mine took a bunch of tries but eventually it just worked... strange but true... I have a blackberry pearl through verizon.
Its not supposed to work, but it did.
Thanks for all the help, fixed my problem. With the Sirius install and using the Y cable, you should not unplug the XM module in the trunk. I reconnected and I now have my phonebook and the import worked.
Originally Posted by ATL06
Thanks for all the help, fixed my problem. With the Sirius install and using the Y cable, you should not unplug the XM module in the trunk. I reconnected and I now have my phonebook and the import worked. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
I assume you plugged both plugs back into the XM (only one of them deals with HFL i think)
How is everything plugged into your stereo with the Y cable??
https://acurazine.com/forums/showpos...&postcount=237
Can you explain your wiring connections? A bunch of us with Ipod adapters are unplugging the XM to get text on the screen.
mlody
12-04-2019 02:11 PM
