Cd's won't play - ? DVD/CD player malfunction
5th Gear
Just wondering if anyone has had the same problem or if you have any suggestions. I have an 05 TL (non-navi). As of a week ago, i cannot play CD's through the 6 disc changer. I tried using one of those cd cleaners (CD with bristles to clean the lens), still won't work. I have tried many different CD's, still nothing. I can hear it spinning the discs, but nothing happpens and after about 2 mins, it spits the Cd's out. I have a feeling that if i take it to the dealer, they are going to charge me an arm and a leg to fix it! Any ideas, has this happened to anyone else? I can't even look into it because the changer is in dash and i have no clue as to where to open the unit up, so i am pretty much helpless. Radio works fine. Thats about all. Any help would be appreciated. Thanks in advance.
I had the same problem with my 02 TL. The CD wouldn't play and spits out after a while. I took it to the dealer and they had to replace the whole thing. It worked like a charm since then. I wasn't sure if my warranty expired at that time but they replaced it for free. Try taking to your dealer and ask to see if they will replace it.
5th Gear
just called the dealership today...they said they would have to look at it but sounds like it needs to be replaced...estimated cost is $1300...what a bunch of BS! looks like its gonna be radio and fm transmitter all the way from now on. not impressed at all! any suggestions?
Fool
03-10-2016 08:42 PM
