Carputer
Old Oct 13, 2006 | 10:20 AM
Final's Avatar
Opium den in
Carputer
So I figured since Im going to have the car for three years a navi and carputer would be a nice touch. I was just wondering what components I would need to put it all together. Any specific specs on the computer or can I just slap on a decent amd with like 256 ram? Any and all comments/suggestions are appreciated
Old Oct 13, 2006 | 10:31 AM
KaMLuNg's Avatar
i would search.. there are plenty of members on here with totally different setups that you could use... there are a million of possibilities you could use to have a good setup... all depends on your preference and most likely, your budget... it is not a relatively cheap project... lolz i know first hand...
another good site would be mp3car.com... it is a site totally dedicated to carputers...
Old Oct 13, 2006 | 11:29 AM
King of Pain's Avatar
I currently planning mine out and doing some research. A couple things to consider.
Power - Car shut and start up controllers are made so you don't destroy the computer when you start your car or turn off the ignition.
Heat - Find a good location with good airflow so it doesn't overheat and die
Touchscreen - Find a touchscreen that will fit the dash
CPU Power - You can probably get by with small mini-itx Computer with a built in CPU like the VIA epia series that integrates video, sound and network on the board. Kinda useless to put a big tower in you trunk.
Here's the link to mp3car. You'll find more info than I can provide.
http://www.mp3car.com/
Old Oct 13, 2006 | 12:39 PM
datmrman's Avatar
Final, you have been here long enough to know how to use the search button, as well as check the 3G TL Garage. Please use those resources before posting a thread on a topic that has been widely discussed on here.
I-013: DIY: My CarPuter Install on a non-navi
https://acurazine.com/forums/showthread.php?t=99102
KaMLuNg
1G TL (1996-1998)
40
Dec 30, 2006 10:57 PM
TokyoJoe
Oct 29, 2006 11:49 PM
youngBuk
Sep 21, 2006 03:34 PM
AcuraCl1
Feb 22, 2006 09:41 AM
KaMLuNg
Feb 3, 2006 08:12 PM
