Car in bodyshop, got it back and sound system is wonky
Old 12-10-2012, 12:59 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
got my car repainted, got it back and something is up with the sound system. obviously the body shop took off all the door panels, etc so they would have to disconnect the speakers and all that.
now, i have a lot of interference like a hissing type sound even when the volume is on zero. it's like annoying dead air sound. also, even more strange, when i have music playing...and put the car in reverse, the music gets quieter...
i haven't torn anything apart yet to see if it's something obvious...just wondering if anyone had any insight on where i should look first.
system is jl 500/1, jl 300/2, jl12w6, massive ck6 front components/tweeters with line driver and crossovers.
Old 12-10-2012, 01:22 PM
Received 16,267 Likes on 11,974 Posts
wiring.
but you already knew that
re-check their work.
Old 12-10-2012, 03:19 PM
LGcbp8's Avatar
As said, wiring is most likely. The hissing/feedback could also be from your gains, any chance they moved them? Not as likely obviously but I'd check them anyway just to be sure. Then you'll know if ya gotta go back there for some words or not
Old 12-10-2012, 04:48 PM
illadelph's Avatar
I went through something similar when doing my install. My problem ended up being the crossovers in the doors just needed to be moved, that was causing the static sound with zero volume.
02-25-2020 09:57 AM
tonio
02-05-2019 05:43 PM
james357
02-13-2016 02:37 PM
aces2412
3G MDX (2014-2020)
09-07-2015 08:40 PM
Quick Reply: Car in bodyshop, got it back and sound system is wonky
