Can a 2008 TL navigation disc work on an '05?
Old Jan 7, 2014 | 08:06 PM
jkilla369's Avatar
Hey guys I just wanted to know if a 2008 disc would work on an 05 TL, and if there are the problems it can potentially cause?
Old Jan 7, 2014 | 08:08 PM
Steven Bell's Avatar
No, it will not work. I think the '05 uses an orange disc. Your '08 requires a white disc.
Old Jan 15, 2014 | 05:11 PM
pearl905's Avatar
i have a 2005 tl
what if i took out the 05 disc drive and put in a 07-08 one, then will the white disc work , is it plug n play?
Old Jan 15, 2014 | 05:17 PM
osvaldo516's Avatar
i currently have the 07/08 dvd nav drive installed on my 05tl and it works. all cables plug right in
some minor glicthes though
Old Jan 15, 2014 | 07:37 PM
pearl905's Avatar
What kinda "glitches"?
Old Jan 15, 2014 | 11:34 PM
osvaldo516's Avatar
clock works but shows wrong time some times
screen calibration at the bottom is off, but you can use the knob on the center to move around and select anything at the bottom of the screen
a bit of unfiltered noise when using Bluetooth
but everything else works fine
Old Jan 16, 2014 | 08:57 PM
kenny416's Avatar
A different story if you decide to place a navtraffic...
Old Jan 17, 2014 | 07:14 PM
Vlad_Type_S's Avatar
Registered Bike Offender
Do you have the disc that came with your '05 or do you have a disc for an 07/08? It sounds like you only swapped the drive.
Old Jan 21, 2014 | 02:35 PM
W_L's Avatar
W_L
Does the HFL work too? If you reused your 05 radio and screen, did you need the navi code of the 05 or the 07/08?
Ol'Dave
Sep 5, 2020 02:56 PM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
