Can 04 Navi gui be upgraded to 08 gui?
I have an 04 TL with the original NAVI interface. I just had a loaner TL and thought that the NAVI interface was a lot better looking. Does anyone know what is required to get the 08 style interface in the 04 TL? Will the DVD software upgrade the interface as well as updating the maps? Is there a newer trunk mounted computer that's required? Thanks.
You going to need a whole new navi computer, dvd player.... 04 uses 3.XX where as 08 model uses 4.XX Its got a pretty much new system in it.
__________________
Kansas City/Missouri Meet!!!
__________________
you will need the following:
New DVD drive
New XM unit
New XM antenna
You will need to rewire the the car or run new wires for the updated items such as the XM nav traffic and the updated screen.
Overall this would cost about 2+K with labor.
New DVD drive
New XM unit
New XM antenna
you could buy the updated dvd for your year and be happy enough!
Originally Posted by redman042
What I'm curious about is, what if you JUST change the DVD player in the trunk? Would you get a working 07 nav without the traffic?
the components will show errors and not function properly. to the poster above, did you put in an 07+ dvd drive into an 04-06 tl? If so, does your radio work from the nav?
Originally Posted by elchapo
my radio is the stock 04 and it works perfect other then xm radio not working properly my fm/am stations are fine and it works thru the navi showing the stations when i press the button to adjust base,treble.etc it shows on the screen the sliders and move fine..the errors you talk of is me not having back up camera,the new updated stock xm unit...the disk i have is the 4.6 white...i did the trick to get out of the diag menu that is common when updating with the new disk,everything runs perfect other then my display clock acting strange from 1am to 12pm
the display unit is different for 07+ TL's than 2004 TL's. There is a Dolby light and a few other ones on there that can cause issues. Try replacing that clock display.
04' Acura TL Anthracite
So what would it cost someone who wants their 04' TL to have the 08 radio etc?
If you had your dealership do it? Replace it all?
From what I can tell the 07/08 now allows scrolling text? Color changes? What else?
mlody
12-04-2019 02:11 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
