Caller ID does not display
Old Jun 1, 2006 | 12:09 PM
chink2nv's Avatar
I just picked up my 06 TL last night. The car drives beautiful. I have my Motorola Razor (cingular) link to the car's HFL. It makes and recieve calls very easily. The battery and signal strength shows on the display. However, when recieving an incoming call, the caller id does not display the number. All it will say is "incoming call".
Is anyone having the same problem? Is it something that I can fix by myself?
Old Jun 1, 2006 | 08:58 PM
Reservoir Dog's Avatar
Cogito Ergo Sum
I have an 06 TL, and my Cingular RAZR displays the caller ID just fine. It does display "incoming call" for about the first two rings, then it will display the number. However, my phone does not display the battery strength on the MID.
Old Jun 1, 2006 | 10:00 PM
Toronto-TL's Avatar
Does the # display on the phone? Perhaps it was a blocked numder.
Old Jun 1, 2006 | 10:29 PM
rimz's Avatar
now with four rings
i've experienced the same thing...when i first connected my nokia 3650 to my TL, everything worked flawlessly when i tested it....my wife called me and it displayed her work number on the dash, along with 'incoming call'....since then, no number has been displayed, but i think it's because every phone call i've received since then has come from a cell phone...i might be wrong, but my conclusion to this problem is it only displays phone numbers on the dash if the caller is calling from a land line...you would think if your cell phone displays the phone number, regardless if it's a cell phone or land line, your dash would display the same thing since it's connected to your phone...
Old Jun 5, 2006 | 10:36 PM
tarheelmm's Avatar
3rd Gear
I have not had this problem. I am using a Treo 650 and have gotten calls from both a cell and land line with no issues. The one thing I did do that helped with some other problems was flashed my phone. Dont know if anyone else would be able to do this but I am willing to help if someone needs it.
Old Jun 12, 2006 | 10:52 AM
ramilford's Avatar
Could it be that the dash only displays the numbers of callers that are in your Acura's phone book?
If they are not in your phone book then maybe just indicates "incoming call".
Old Jun 12, 2006 | 10:59 AM
edsonfire's Avatar
05' WDP A-SPEC
ive been having the same problem. when i first started using the bluetooth, it was fine but recently i noticed the caller id only works sometimes. i havent been able to pin any kind of consistancy to it yet but i plan to bring it up with my next service.
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Froid
Sep 27, 2015 06:16 PM
dirleton
Sep 25, 2015 12:25 AM
