Call Waiting, Call Dropped; Razr V3
A Motorola Razor V3 is paired with my TL. Recently I've noticed that when on a call and a second call is announced via call waiting, both calls are droped if I ignore the incoming call.
Has any experienced a similar situation?
Is this realted to the phone or to the HFL?
TIA
Bob
TIA
Bob
Originally Posted by icecrepas
I've had no such problem
... is it just me, or does the battery drain extremely quickly, when paired with the hands free system??
I also own and pair a razr with my '05 tl...
I've had no such problems, but is it just me,
Nope, I have never had any problems with my Razr. Everytime when I would get a 2nd phone call, it would put them on hold. Thats wierd.
TIA
Bob
TIA
Bob
Does anyone else have any suggestions on how to fix this. I know it is not a problem with the car since this never happened with my Sony Erricson cell phone.
Thanks.
i have a problem with the V3... im not sure why it dosn't do this all the time... and im not sure if it did this with incoming or outgoing calls and ive noticed it did this after a previous call... i answer the phone or call someone.. it rings... i hear them say hello... then it goes dead.but the radio dosn't come back on or anytihing. . and im sitting there... hello, hello... then i notice on the phone it still says connected. So i quickly have to push the HFL button and say "transfer" and it goes back to the HFL...i have do recognize that it is doing this and act fast or the person on the other line will hang up...... does anybody experience this problem.. i think it is a little different that what RCBLACKWELL was talking about
Originally Posted by jmbnova
OK.. my Moto V3 does the same drop call thing, but not what you were talking about drdamian
what does it do??? does it drop the call completely and you have to call the person back...??? its not 2 much of a bother for me.. not enough to have the dealer rip it out and put a new one in... at least not for now.. unless someone here tells me that they have had the same problem and it is broke..
Just an idea, but I've read posts of people that have had great experiences with the CDMA RAZR and then some people in this thread seem to being having a horrible experience.
This should be the latest version firmware for the VZW RAZR
01.0F.03P
If you're having problems, check your firmware and see how it compares. If you're at a lower rev, you might want to bring your phone to a VZW owned stored and have them flash it for you.
01.0F.03P
I have the same problem.. but there is 1/2 a workaround. When you are on a call and a call comes in and you don't answer the incoming call, the HFL disconnects but the call is still active on the phone... if you press the 'call' button on the HFL control, the call will come active on the HFL... if you do this immediately the other party doesn't notice anything. i wish it would work 100% but, oh well.
I used to have a Motorola V600 and when paired w/ my 2004 NBP, there was a documented problem w/ answering calls over the HFL while the phone was in closed (not flipped open). When i got my 2005 SSM, the V600 did not have that problem, and everything worked perfectly. So its not the phone all the time.
Originally Posted by vtec1jk
i have the exact same problem with My Cingular Razr. I even got a new Razr just to see if it would make a difference. Didnt help at all. Did anyone find a solution?
Bob Blackwell
Pickering, Ontario
I am curious because we may be buying a RAZR.
There are multiple flavors of RAZR V3....
http://www.acura.com/models/handsfre...rrer=ownerlink
When people here talk about the V3, are they meaning the Cingular/TMobile GSM version? Does carrier matter here?
Note that Cingular has a particular firmware rev. although I assume anything after that rev is OK.
When I initially bought the car, the BT feature worked without issue. What happened???
Eggs999bacon
09-24-2015 10:08 AM
4drviper
09-23-2015 07:42 PM
