Bypassing NAV Disclaimer
Overlord of Networking
I am sure this issue has come up once or twice, however , you see i am a bit of a hacker... Anyway, i was wondering, is the disclaimer that pops on the nav screen after you start the car is embeded into the nav system (eprom) or does it reside on the NAV DVD disk?( just like the FBI warning you must watch when you pop in a DVD into your home system). Because i was thinking that if it resides on the disk, than it is very easy to get around.. however i do not think Acura would be that dumb? Maybe they would.. i dont know.. if anyone has the info let me know. Thanks.
registered !!
cant u find out if it does or doesnt reside on the dvd disk. Like pop it in the pc, and search for a specific, lol im sure u already thought of all that. Just that i am as irritated as anyone else that it takes its time to load up so i can use the navi in my car.
It takes time to boot up computers. The warning sign is part of the boot up. If it wasn't there, you still would not be able to use the navi. I kinda like the screen. If you don't hit OK, the screen goes to sleep. Unless I'm lost or need to find my way home, I don't use the navi that much. It's a great backup though...
Ak Ting Up
04 5AT ABP/Camel
FWIW: I also own a hand-held GPS from Garmin (E-Trek vista). And it takes several minutes longer than the TL to find the satellites and establish my position when I turn it on. During this time, the display reads “Finding Satellites”.
TL hacker
The disclaimer is on the nav DVD disc. However, the EPROM in the nav is what triggers it to pop up. I tried hacking some files of my own but you have to be careful. You mess up and you'll have to bring it back to the service dept to get it re-tuned. Rebooting from scratch isn't much of a problem but the nav has values for calibrating tire size and other things that are done at the factory. If you mess those up, it's back to the service dept.
In any case, hacking the nav is fun and you can discover some really fun things but it's risky and not recommended.
Ok well.. That is good information.. Unfortunaly i do not have my TL yet so i cannot try this, however, what about making a copy of the disk and working off of that. If i made a copy of the disk then i would basicaly eliminate the warning alltogether. This is a very simple process. It works on my DVD players to eliminate the FBI copyright warnings on DVD Movies.. I dont think it could be that hard for the NAV system. Once i get my TL I will begin testing. If somone else wants to try it I can walk you through the proces if you need. You need to have a basic understanding of how to copy and re-author a DVD movie. Aso, i imagine you need a dual 8gb burner and 8gb media since i belive the NAV dvd to be of the 8gb double density naure. These dual burners are new on the market, however i know of one that can be purchased as a single density DVD burner for 69bucks and be firmware upgraded to double density for free. Also, i use Adobe premere to recompile the movie without the FI warnings and such. Once that is done you can use DVD-it or anyother DVD authoring program to compile the dvd and burn it.
Again, I will be doing testing once i get my TL.
I don't mind the screen, but I do mind the fact that I have to hit OK EVERY SINGLE TIME. I realize that it takes awhile for the disc to spin up, the receiver to get a position fix from the satellite, and for the proper map to be displayed, so I don't mind the wait.
I just wish there was a way to make the car remember that I have already said OK to this disclaimer a thousand times already, and stop prompting me already. Thank you, car, I realize that no navigation system is perfect. I realize that roads change. Now stop making me hit OK every time I get in the car.
One nice feature would be if the car could remember what the last screen displayed was. For instance, I usually leave the screen on, but mostly I have it set to display the audio properties. It would be nice if, when I get out of the car, it would remember that the audio screen was the last one displayed, and display it automatically the next time I got in. Just like the memory seating. I could live with the OK screen then, because it would only pop up when I actually manually switched over to the map mode.
Oh well...it's a pet peeve, and seeing as how this car is so damn perfect in every other way, I can live with it. Not like I have much choice, anyway...
Matt
Matt
By the way, is there a way to turn the nav screen off manually? I know that if you don't hit any buttons when you start the car up, it will go off automatically after a few minutes, but I would like to be able to turn it off sometimes.
If this info is in the manual, then I apologize for posting this question. I know people would respond saying read the manual...so sue me...I haven't read the manual yet...at least, not cover to cover. I read the sections that interested me, and the ones that dealt with car maintenance...
Matt
Matt
Anthracite Trend Setter
Matt
Matt
Press set up, the off
Still, it might be fun to replace the CYA warning screen with something else, like a picture of my car that says "Fuque's Pimp-Ass Ride."
Just remember to read your manual. Hacking the DVD software is ILLEGAL. It says so right in the nav manual. It specifically states that reverse engineering, or alterations to the data on the disc are strictly prohibited. This would probably mean that, if Acura ever found out, not only could they prosecute you for tampering with the software, but to a lesser extent, they could void the warranty on your vehicle.
So, do this at your own risk. There was another post awhile ago where someone wanted to have a device that would automatically hit the OK button for him, instead of hacking the disc. He hooked an oscilliscope to the navi and found the pulses of data that get sent over the lines when the OK button was pressed. He wanted a device that would mimic this response, so that, every time the car was powered on, instead of manually hitting the OK button, this device would trick the navi into thinking the OK button had been pressed, and proceed past the disclaimer screen. This would seem to be more legal than actually hacking the disc, because there is no alteration of the program data either in the EPROM or on the disc.
And if you read the nav manual, it also states that the OK button does not appear until the system is actually booted up and ready to use, so TXTL is correct. Even if you got rid of the OK screen, something else would have to takes it's place, since the system would still not be ready for use.
Matt
Matt
Team Anthracite Webmaster
i don't think the warning screen is required to cover up the boot up, the system probably boots pretty quickly - all my other car navs have in the past (honda, toyota). i'm pretty sure the delay is to require you to read hte message, unless there is some reason the acura system is slower.
i agree that i wouldnt mind the message if it would go away by itself instead of having my press okay. i think i'll take a look at the dvd later today.
The OK button came up MUCH more quickly on my 2000 TL DVD Nav system. The 2004 has a faster processor. I'll bet they've purposely delayed the appearance of the OK button at the request of their lawyers. Notice have they've made driving the TL safer by making you stare at the damn screen waiting for the OK button to appear while you're trying to back out of the driveway.
never stops!
See if this helps to reduce the time. Let the nav display the screen, ignore it and then when you really start to drive, push the voice command button when OK is displayed immediately and then acknowledge it. Again this is my way for not waiting for OK to appear on the screen.
Team Anthracite Member
I don't own a TL so how long does it actually take from the time you start up the car until you can press okay and proceed?
And does your tip about using the voice command to "okay" the disclaimer actually work?
thanks,
carcar
thanks,
carcar
Team Camel Executive VP
thanks,
carcar
thanks,
carcar
The bad news: It's repetitive and annoying to have to hit 'ok' all the time.
The good news: Like anything else repetitive, it becomes second nature after awhile and now I glance at the screen at the perfect time to see the 'ok' first appear and tap it with my finger so quickly my eyes really don't leave the road for more than a split second.
BJ
It takes about 20 seconds. I start up the car, back it up, head up the driveway, and by the time I've cleared the neighbors mailbox the 'ok' is there and ready to be tapped.
BJ
BJ
Wait, how do you back up with the camera? I have a 2017 RDX and it does not allow me to see the backup camera until that screen is gone…
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
