Burn DVD Nav disc?
Old Nov 5, 2009 | 06:48 PM
  #161
dwb993's Avatar
A lot of people have invested a lot of time on this issue. If you think you have a fresh approach, do the research, make it reproducible and share with us all, please.
Old Nov 5, 2009 | 06:53 PM
  #162
DurgyNess's Avatar
Im looking into it, im sure ill end in epic fail too
But i like to know i failed trying with out being told the answer
Old Nov 6, 2009 | 04:16 PM
  #163
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
DVD Burning with white disk 07-08 TL
Hi guys, i'm new to the site, i think its great, I have a 2007 TL Type-s and i just want to give you guys my experience with the navi disc burning issue. I was able to burn the NAV DVD with nero 7 as a disk image no problem, and then i burned the image to a dual layer DVD DL+R and it wasn't able to read it. I then tried again with a DVD DL-R. And it still gave me the disk read error. I then tried to trick the unit by putting in the OEM disk and pushed the ok button. Once it was operable i took it out again, put in the copy and then it worked but only with a DVD DL-R. It seems that an upgrade has to be done with the original disk, once the update is done with the OEM disk then it will read the copy but only with a DVD DL-R. I've been using the copy in my drive for over a month now with no issues to report.Hope this will help you guys out.
Old Nov 6, 2009 | 04:19 PM
  #164
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
Just to add i don't know if this trick will work on older generations TL's
Old Nov 6, 2009 | 05:22 PM
  #165
dwb993's Avatar
What version NAVI do you have?
Old Nov 6, 2009 | 07:48 PM
  #166
toslat's Avatar
The 2007 TL uses the white disc.
back to the orange, the drive not reading the disc could be from
1. Hardware+firmware+drivers i.e. The drive cannot read OTP disc as suggested by some.
I doubt this as the OTP was part of the original DVD-ROM specifications. The main consequence of OTP vs PTP is the mapping between physical locations, sector numbering, and LBA.
To eliminate this would require someone carrying out one of the known working hacks (like background change) using an OTP disc. To be thorough, the files should be burned onto layer 1 (as layer 0 is independent of track path).
If the player cant read OTP discs, then we will have to find out how to reduce the database sizes and fit them onto a 4.7GB disc.
2. ROM program: The ROM program can run simple checks like looking for a specific file at an LBA. Those that have tried it can check the LBAs of each file on the two disc for mismatches.
3. On Disc: This is the most likely culprit as it gives Alpine the most flexibility across different hardware. Which means proper arrangement or edit of the files should make it possible.
Unfortunately I dont have DL discs at present so cant get much done yet
Old Nov 9, 2009 | 12:49 PM
  #167
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
hi, i have the white disks and version 4.56a
Old Nov 9, 2009 | 12:58 PM
  #168
DurgyNess's Avatar
Well i used a lite on drive with verbatim dl disc
and i used imgburn and read the isofile first and checked to see the sectors on that and then i burned the disc at 2.4x and
the sectors / data on my second disc was not the same as the iso, it was off by 1 or 2 k/b in a layer.
This maybe the problem.
But when i checked this is it said the iso was in OTP
and my burn was in OTP
Old Dec 7, 2009 | 11:52 PM
  #169
furjaw's Avatar
Originally Posted by flash2021
the new Orange disk is out (v3.9) so I thought I'd give this thread a BUMP...any advancements?
I just received my 3.9 orange disk. I tried to copy it with Nero 7 to a Memorex DVD+R DL. I got a write error.
Old Dec 11, 2009 | 02:01 AM
  #170
badteddy's Avatar
has anyone tried creating an iso and then burning it? i had issues where i had write errors so i just created an iso of it. another thought is has anyone used dvdcrypter on it as well?
Old Dec 22, 2009 | 02:10 PM
  #171
Realestatepro's Avatar
Has anyone tried making a back up of the new 2010 upgrade cd? i beleive its V 4.81? any success?
Old Dec 24, 2009 | 05:13 PM
  #172
Riga89's Avatar
B A N N E D
I wanna know this too.
Old Jan 21, 2010 | 06:49 AM
  #173
encryption's Avatar
so I did manage to snag 3.9 and burnt it to a Verbatim DL disc using Win7 image burn. It failed. Navigation does not recognize the disc at all. I tried twice to "load" the disc from the operational screen but it didn't work. Stuck in my original from 2003 and it booted right up.
I did however notice a section where it says "load from disc" it also says "load from card" (or something similar) can we perhaps copy the loading files onto a flash card and have the system boot from it instead (since burning has been a problem)?
Old Jan 26, 2010 | 01:02 PM
  #174
encryption's Avatar
*bump*
Old Jan 29, 2010 | 08:55 PM
  #175
Jnwade's Avatar
7th Gear
Originally Posted by ifirahse
I've been able to duplicate the 4.63 quite easily. There's an image going around internet that has worked perfectly for me.
In fact, I've had a copy in my TL for the past couple weeks with 0 errors...it seems to load faster than OEM.
So, could you share where you found this image on the internet? Many people seem to have a copy of the .iso's floating around, but like everyone has said, they don't work once we burn them. We'd all love to know where you found your copy!
Old Jan 30, 2010 | 01:20 AM
  #176
ifirahse's Avatar
SlammedOnKonis
There's a torrent on demonoid now.
Search "acura 4.63"
Old Jan 30, 2010 | 11:54 AM
  #177
Jnwade's Avatar
7th Gear
Search "acura 4.63"
Thanks for the info!
Old Feb 24, 2010 | 04:29 PM
  #178
AUTigersGrad's Avatar
Anyone have any luck with the 3.9 version? PM me if you have.
Old Feb 25, 2010 | 10:17 AM
  #179
encryption's Avatar
negative, apparently if you change some files that contain the street names and POIs to 0 byte sizes, you can burn the iso to a single layer dvd, which then allows the navigation to load. but that's pointless.
Old Mar 11, 2010 | 01:25 PM
  #180
schvaz14's Avatar
ok, who is going to be the first to file share the ISO Images on a server so we can all try to burn?
Old Mar 11, 2010 | 01:28 PM
  #181
dwb993's Avatar
^^Ummmm, did you actually READ any of this thread?
Old Mar 11, 2010 | 06:20 PM
  #182
jjlim's Avatar
Omg, there are only orange and white version iso. Could anybody let me know where I can get black ver. iso? is there only me who're looking for black ver.?
Old Mar 20, 2010 | 09:30 AM
  #183
Roger555's Avatar
OCD
flash the nav dvd rom firmware!!!!
Old Mar 23, 2010 | 09:17 AM
  #184
xavierhn's Avatar
Out of Rice
I was able to duplicate 4.63 very easily; however, i still have 4.62 original disc as a backup. Always good to have them, you can't really rely on copies because you never know when you're going to get an error. Best advise is to leave the original back up in the car (taped it up in a cd case so no scratches or finger prints can get to them).
Old May 17, 2010 | 09:59 AM
  #185
ravenan's Avatar
8th Gear
I borrowed my friends '08 TL disk to try in my '07 RDX to see if they had included any of the new streets in my area. This test couldn't have turned out worse.
1. My old NAV-DVD doesn't work anymore as it's an older version.
2. They still haven't included the new streets in my area.
Does anybody know how to reset the navi to use the old NAV-DVD as I need to give my buddy his dvd back.. ;-)
Old May 17, 2010 | 04:38 PM
  #186
dwb993's Avatar
^^Remove your friend's disk and disconnect the battery for 5 minutes (make sure you have your radio and navi codes). When you reconnect, insert your original disk and let it load.
Old May 18, 2010 | 01:32 PM
  #187
ravenan's Avatar
8th Gear
Thanks for the reply I will try this ASAP.
Old May 18, 2010 | 01:38 PM
  #188
alann's Avatar
any new updates on burning the orange discs (3.9)?
Old May 18, 2010 | 06:53 PM
  #189
ravenan's Avatar
8th Gear
This tread had me worried that it might be hard to burn a copy of the white navi disk 4.62 I was able to make a backup on my first try with a Verbatim DL+. Let me know if you have any questions. The burn took about 25mins.
Old May 18, 2010 | 08:42 PM
  #190
dwb993's Avatar
Yeah, the white disk has been known to work. You can grab a copy of 4.63 from Bittorrent, if you want to upgrade!
Old May 19, 2010 | 09:44 AM
  #191
alann's Avatar
damn it, why's the orange disc gotta be so hard? you would think since it's older than the white discs, it would be easier to burn.
Old May 19, 2010 | 01:17 PM
  #192
ravenan's Avatar
8th Gear
4.63...what year is that one? Has anybody successfully backed up 2010 maps?
Old May 19, 2010 | 05:08 PM
  #193
dwb993's Avatar
4.81 is current for the white disk.
alann: The orange disk uses a different copy protection scheme. I understand that it is indeed crackable, but noone has done it yet. That is way beyond my skills.
Old May 19, 2010 | 07:00 PM
  #194
alann's Avatar
yeah, pretty sucky but i guess those of us with 04-06 navi's will have to either wait or shell out $150 for the update.
Old May 19, 2010 | 09:48 PM
  #195
ILLustriousUA6's Avatar
Feenin on some 20's
I just bought the update online for about 160-170 shipped(Irvine).
Old Jun 3, 2010 | 10:08 PM
  #196
TL-S Driver's Avatar
Any luck coping the 4.81? I would really like to make a copy, but it is just not working, i have tried many differnt CDs and buring software, i can make a copy but the NAVI does not recgnize it. Please help
Old Jun 5, 2010 | 10:12 AM
  #197
YouLoveTamz's Avatar
Sounds like a no go on the Orange v3.9?
Old Jun 5, 2010 | 11:40 AM
  #198
dwb993's Avatar
If I recall correctly, you need to use a DVDR-DL to copy the 4.xx disks. I'll have to check my GF's Accord to make sure. The data will not fit on a CD-R.
Old Jun 5, 2010 | 12:07 PM
  #199
jsilas's Avatar
THƎSƎ HOPƎFUL MACHINƎS
Subscribed...
Old Aug 9, 2010 | 09:50 AM
  #200
Waltah's Avatar
bumping...
i think i found the answer as to why we cannot create an operable nav dvd. forgive me if it has been explained...
http://www.gearsoftware.com/support/...opic.php?t=546
reading the info fro that link, the way the acura DVD is wrtten onto the disc is called PTP parallel track path. currently there is no recordable media (blank dl-dvds) that can have PTP written onto them, nor is there a DVD burner that can write in PTP.
seems like the only thing stopping this from working is finding how to write data in the same direction and pattern as the original disc so the dvd unit can read it. its not that we are copying the data wrong, its that we are unable to write it in the correct direction on the new disc.
looks like a NOGO
DDP is only used by professionals. It is the format for the DVD master that is sent to the factory for mass replication. The encoder on the laserbeam recorder reads the DDP image in order to cut the glass master. The glass master is electroplated, in order to create nickel stampers. The stampers are loaded into an injection molding machine (one for each layer), creating DVD disc substrates (0.6 mm thick). The layer 0 substrate is partially metalized with silver, to a reflectivity of about 30%. The layer 1 substrate is coated with a fully reflective layer of silver (if I recall correctly, the reflectivity is almost 90%). The 2 substrates are bonded together, with the information layers on the inside. This is how pre-recorded DVDs are made.
Recordable DVDs, on the other hand, are manufactured with a "pre-groove". The burner follows the pre-groove during recording. This means that the burner doesn't have to have super-precision mechanical components, like massive air bearings and linear motors (with interferometer linear scales) in order to precisely space the tracks 0.74 microns apart. The laserbeam recorder creates a DVD-R (or DVD+R) master with a pre-groove, and the DVD burner has a servo tracking system that can follow the pre-groove. The pre-groove also has a slight wobble which contains timing information. The burner can read the wobble, and synchronize the rotation speed to the wobble signal.
So, anyhow... there is a big difference between replicated DVDs (mass produced, pre-recorded, no pre-groove, no dye layer, etc.) and recordable or duplicated DVDs (burned by a DVD recorder onto a dye layer, on top of a pre-groove).
I hope this helps you more than it confuses you!
