Bluetooth Fails
Old 11-03-2015, 08:52 PM
  #801
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
Originally Posted by sockr1
Bump to see if that's the same capacitor fix for a 2007-08 type s?
I tried this for my 07 tl-s, didnt fix it. I would recommend going with the $45 repair
sockr1 (11-03-2015)
Old 11-06-2015, 01:47 PM
  #802
Jchick's Avatar
Just wanted everyone to know that I sent my Bluetooth module to Joel, received it back within a week, reinstalled and was back in working order. Been running fine for a week.
Thanks Joel - Best $45 I've spent on the MDX in a long time.
PS - I had previously replaced the capacitor and did my own oven baking but that did not fix it.
GodinTechnologies (11-19-2015)
Old 11-08-2015, 01:26 PM
  #803
4th Gear
nerdindenial's Avatar
Unhappy Replacing HFL Did Not Help on 2008 TL-S
I have a 2008 Acura TL-S with only 35K miles that is on its third battery. The car won't start a few times a year because of the infamous Bluetooth Hands Free Link (HFL) battery drain problem. The HFL always works perfectly, but it drains the battery. I just replaced the version 1.2 HFL unit with a new factory version 2.0 part from a major online Acura dealer, but the HFL mounting area behind the rear view mirror remains warm even after the car sits all night. I've taken to carrying a jumper battery in the trunk to prevent stranding.
Is there some other part that should be replaced? Should I return the new HFL unit and get another one? I really don't want the dealer to go on a $1000 fishing expedition. Please advise.
New factory HFL has SW Version 2.0
Old 11-08-2015, 01:35 PM
  #804
5th Gear
07TS's Avatar
This is the part I'm taking about. Does any one know how to disconnect that grey box on the top of the pic next to the hfl module?
I didn't see diy tutorials mention anything about that.
Thanks!
Old 11-08-2015, 01:59 PM
  #805
4th Gear
The gray module at the top of the picture is the MX217... microphone ($95 at oemacuraparts), which is attached to my interior color's black plastic carrier with 2 Torx screws. It has an attached wiring harness with a white plastic roof attachment cone at the midpoint. This cone can be released from the hole in the roof by pressing in from the sides (first on one side, then on the other) with a thin screwdriver while pulling down on the plastic. Then the white wiring connector shown at the bottom of the picture can be released by pushing on its release tab with your fingernail. When you buy a new HFL it arrives mounted to the large plastic carrier, but the microphone is missing and needs to be transferred from your old plastic carrier to the new one. The plastic carriers come in several colors; that is why you need to order by VIN number at oemacuraparts.com. It is good that they provide a new plastic carrier, as the old one is often cracked in many places (superglue will make a passable repair, though).
Old 11-09-2015, 09:06 AM
  #806
pawelTL6MT's Avatar
My 2006 TL HFL stopped working a few weeks ago. I changed out the capacitor and it works for the first few minutes, but then stops, and the message is
NO INFORMATION AVAILABLE
anyone else have this issue, any ideas what the problem is?
Thanks in advance,
Pawel
Old 11-09-2015, 10:51 PM
  #807
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
meaning the HFL has drop the connection to your phone.
Old 11-10-2015, 08:22 AM
  #808
pawelTL6MT's Avatar
I retested by just hanging the unit out and it stays connected no problem. Weak Bluetooth connection from the unit?
Old 11-10-2015, 08:51 PM
  #809
truonghthe's Avatar
it will connected but some time it will drop the connection for couple mins before reconnecting, mine unit does that before taking a dump on me.
Old 11-11-2015, 11:07 PM
  #810
4th Gear
Replacing HFL Did Not Help (at first) on 2008 TL-S
UPDATE 11-11-2015: After I replaced the HFL with a new factory unit, the headliner area covering the HFL remained warm, even after sitting all night. This went on for several days and finally the battery was dead after the car sat for 2 days. So I jump-started the car and kept checking every day to see if the HFL area was warm. To my surprise, it has been 4 days and the area around the HFL is now completely cool! So apparently it was necessary to disconnect the battery during or after when the new HFL was installed so the system could get its on/delay/off functions synchronized?!? Just shows how complicated this system is.
It seems that the people on this thread are fighting at least 2 different problems: (1) Dead battery, and (2) HFL that does not work.
In my case it is only problem 1, although some people seem to have both problems. I'll post an update if my new HFL goes bad again. I don't know what other components there are to replace on a 2008 TL-S. Is there some sort of delay switch mounted behind the Navigation unit?
Old 11-12-2015, 10:48 AM
  #811
eastcoastguy's Avatar
What car are those pictures from, that doesnt look like its from a 2008 TL-S?
Old 11-12-2015, 10:55 AM
  #812
4th Gear
@eastcoastguy
Yes, the HFL picture is from a silver 2008 TL-S that I have owned since new. The interior is black and gray. This is the only substantial trouble I have had with the car, other than it eating Brembo brake pads every 15K miles.
Old 11-12-2015, 12:05 PM
  #813
sockr1's Avatar
Received 1,159 Likes on 909 Posts
@eastcoastguy
you must brake hard haha. i'm on my 2nd set of rotors and pads and i'm at 105k miles. i haven't even changed the rear pads or rotors yet. i'll be doing a full set replacement before the end of the year
Old 11-20-2015, 01:42 AM
  #814
I was planning to send it to godin technologies in FL, but I found out that I was lucky enough to have a friend who owns an electronics manufacturing shop to have a solder reflow oven here. We took the gray connector out earlier tonight, and will be putting it through the solder reflow oven with flux tomorrow. I believe this is the exact same procedure they do over at godin. In any case I'll report back tomorrow with the results.
Here is a picture of the oven that my hfl unit is going through tomorrow:
Old 11-23-2015, 03:44 PM
  #815
Got my pcb back! It's working so far! Woohoo! And was able to get it done for free in my own city since he is a friend.
Old 11-24-2015, 03:10 PM
  #816
sockr1's Avatar
just got my board back from joel and the HFL paired right away and is working!! so excited this only cost me $45, thanks joel and to the other members who recommended him!
just don't make the mistake i did...i sent in the wrong board because i didn't know the HFL one was under another console cover for the 2008 model (it was hidden)! he emailed me back after a week and said he needed the board that contains a "broadcom" chip....so i went back in my car and took out another plastic console and yup, there was the other board.
so it took 2 weeks instead of 1 but at least it all works now. and i can finally have interior lights again haha (i took it all apart and left it apart til i got the HFL board back)
Old 11-24-2015, 05:29 PM
  #817
I actually have 1 more hfl board that died a couple years ago(my first one) that I'm thinking about getting fixed and re-selling here.
maybe this time I can put the board under the xray machine at my friend's shop and see exactly which parts of the solder joints are breaking
Old 11-29-2015, 02:29 PM
  #818
ScottS's Avatar
I just got my HFL back from sending it to Joel and it works great. Joel turning it around the very next day once he received my unit. It is so nice to have Hands Free working again.
$45 was an extremely fair price to solve this. At the time I posted this (November 2015) a new unit online would have cost me $283. This was simply not an option for me.
I highly recommend !
Old 12-03-2015, 12:47 PM
  #819
henlinet's Avatar
does anyone know if the HFL module from another vehicle of same year is compatible with a 07 TL. Mine has bit the dust. I have tried the oven thing and it worked for a little while but I need to replace it. I cant see spending 228.00 on a new one.
Thanks,
Terry
Old 12-03-2015, 01:32 PM
  #820
sockr1's Avatar
Thanks,
Terry
why don't you do what everyone else in the thread is saying? send it into Joel at Godin Technologies. $45 and you're good to go!
Old 12-07-2015, 04:39 PM
  #821
5th Gear
07TS's Avatar
Got my unit back from Joel at Godin
My hfl works like a charm now
Glad I don't have to buy a new one
hcrew3926 (11-21-2016)
Old 12-09-2015, 09:43 PM
  #822
ColoradoRob's Avatar
God Bless AcuraZine and Godin Technologies!
I too had a Bluetooth Failure in my 08 TL. After reading this thread, I sent my circuit board to Joel at Godin Technologies, along with a check for $45.
Joel sent it back within a week and it's working like a champ! I can't recommend Joel highly enough! Save your hard-earned money and give him first shot at your Bluetooth.
Godin Technologies
795 Commerce Dr. Ste 3
Venice FL 34292
Old 12-12-2015, 10:18 PM
  #823
klept0's Avatar
Thumbs up
I'm just checking in as another successful repair from Joel. Being close to him I had a literal 4 day turnaround time from shipping to receipt and back in my hands. Installed and it paired without hesitation - here is to no more dead batteries!
Old 12-20-2015, 05:55 PM
  #824
3rd Gear
pigsfly's Avatar
I recently purchased a (used) 2008 Acura TL Type-S. Everything about the car is great except that a) The voice recognition is terrible "Fan off" becomes "Display icons" or something else completely random and b) the HFL does not work.
HFL issues:
1. When I checked the main diagnostic test it (HFL) lit up red.
2. I tried holding the [TALK] and [BACK] buttons at the same time on the steering wheel and nothing happened.
I didn't even realize my HFL wasn't working until I tried to pair my phone and had issues with the voice recognition. Do you think this is merely an HFL issue or due to the voice rec. there could be more at play?
If it's just HFL I'll send it to Joel and see what happens.
Thanks for your help.
Old 12-22-2015, 01:07 PM
  #825
emegge23's Avatar
Godin Technologies
Venice FL 34292
How I can contact Joel to send mine?
Old 12-22-2015, 02:06 PM
  #826
sockr1's Avatar
really? everything you quoted in your post has the info to send it in. reread (or read for the first time) the post you quoted
Old 12-22-2015, 08:31 PM
  #827
emegge23's Avatar
Unhappy
I mean, How can I contact Joel, everybody talks about Joel, but it's no any email or phone number to contact him to make a deal and let him know that I'm interested to send my HFL to him.
Sorry, if for some reason I offended you, or any member of the forum.
Old 12-22-2015, 10:02 PM
  #828
sockr1's Avatar
You don't need to contact him. You can just send it to the address above with a check. Make sure your return address is on it.
You can email him if you want, his email is joel.godin@gmail.com. I originally found it by doing a Google search on the company name. You can let him know it's coming but honestly he'll just tell you to send it to te address above with a check. You'll get it back a week later.
The following 2 users liked this post by sockr1:
emegge23 (12-23-2015), JFixit 07 TL.S (01-01-2016)
Old 12-23-2015, 09:38 AM
  #829
3rd Gear
pigsfly's Avatar
Telephone
1-941-773-3848
FAX
1-206-339-3776
Postal address
795 Commerce Dr Ste 3
Venice, FL, 34292 USA
Electronic mail
General Information, Sales, and Support
Joel.Godin@gmail.com
Godin Technologies
The following 3 users liked this post by pigsfly:
emegge23 (12-23-2015), JFixit 07 TL.S (01-01-2016), tomjonesrocks (06-24-2024)
Old 12-23-2015, 09:33 PM
  #830
08Acura13's Avatar
Used Godin Tech sent a money order and a note with my contact information. Less than a week later I got my HFL module back working like a charm! Had tried the baking trick it worked for a little while. Then I tried to re-solder a few spots (lucky I didn't mess something up) worked for a little while. Saw this company on here and I figured it was worth a try for $45...guy seems to know what he's doing. Very pleased so far!!
Old 01-06-2016, 02:18 PM
  #831
GOOSEej's Avatar
does anyone know if this same method will work for a 2006 TSX?
Old 01-08-2016, 03:15 PM
  #832
johnnyham89's Avatar
Has anyone heard of the devices failing after the repair by Joel?
Old 01-09-2016, 10:45 AM
  #833
Mine was repaired three months ago and is still working great. I am not sure there are any people out there that have had it repaired for much longer than that. Time will tell if this repair holds up, but so far myself and others are happy.
I will continue to update from time to time to let others know how the repair is holding up.
Old 01-09-2016, 05:24 PM
  #834
mazen222's Avatar
Nice! i didnt know someone found a working permanent solution!
I'll be shipping mine soon!
Old 01-21-2016, 06:49 AM
  #835
pawelTL6MT's Avatar
Just wanted to share with you guys.
My HFL stopped working so I initially replaced the capacitor and it worked for about 2 weeks. I didn't want to bake it, so I sent it to Joel.
He got it last Thursday, fixed it and shipped it out same day!!!
I wasn't able to install it till yesterday but all is well again.
Thank you Joel!
Old 01-23-2016, 11:45 AM
  #836
mazen222's Avatar
Shipped mine 2 days ago! Waiting now
Old 01-24-2016, 06:07 PM
  #837
mine is still holding up well, had it fixed 2 months ago.
Old 01-24-2016, 06:51 PM
  #838
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
How much did it cost you to ship it out to him from Canada?
Old 01-26-2016, 07:21 AM
  #839
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
I baked mine four days ago and it seems to be working fine so far.
Old 02-19-2016, 12:47 PM
  #840
4th Gear
200k 2006 Acura TL's Avatar
I got my board back from Joel, Works great $45 buck...good deal!!
Quick Reply: Bluetooth Fails
