bluetooth compatibility
can anyone tell me if the motorola V710 with verizon is compatible with the bluetooth in the 2004 TL, my friend has that phone and i cant get it to link up to system, the phone does have bluetooth
the icon flashes on his phone like it is linked up to my car, but my car doesnt locate the device, unless i am doing something wrong
i am basically pressing the pick up button when i come into the car for it to link up to phone, all the screen says on the dash is main??
can anyone give any assistance
Spend your own time reading the manual and then if you have trouble come here and spend our time reading it for you.
Mike
Mike
V710
Tongy24- You should be able to use this phone with the TL, however you will experience frequent problems until the new software is available. I would read through your manual again to get linked up . See Below...
The motorolla v710 is listed as bluetooth compatible by motorolla, but is not approved by acura unless it has a specific software serial number. Acura has worked with Motorolla to resolve the compatibility issues that this phone intitially had with the TL. New software will be available to the public by the end of this month. You should check with your phone dealer periodically, and make sure that they are aware you will need the new software. When your store has the new software, the fix will take 15-20 minutes.
Good Luck--
JWL
Good Luck--
JWL
thanks, that was the specific info i was looking for, better than the other wiseass remarks
https://acurazine.com/forums/showthread.php?t=100500
Mike
MetalGearTypeS
08-29-2016 08:28 PM
SUPRMN84
10-07-2015 09:46 PM
adreano17
09-29-2015 08:48 AM
