Bluetooth "booting up" and frozen
Greetings all,
my '04 TL's bluetooth system seems to simply freeze when I select it from the menu. It says "Booting up..." and that's pretty much all I can get out of it.
Any advice or should I simply take it to the dealer?
Best regards
-DM
Best regards
-DM
Registered but harmless
Received 1,102 Likes
Welcome to the forums.
See https://acurazine.com/forums/showthread.php?t=150409 for another member with similar HFL issue.
My advice:
If you haven't done so already, try letting the car go through a full on-off cycle with at least a half hour off. Then try the HFL again.
If that doesn't cure the problem, try a battery disconnect.
After that, it's a trip to the dealer-- in other threads, a couple of members underwent HFL replacement when theirs would not unlock.
My advice:
MetalGearTypeS
08-29-2016 08:28 PM
SUPRMN84
10-07-2015 09:46 PM
