Blitzsafe Installation
So my wife just bought a 2006 TL (AM)
I bought her the Blitzsafe kit for her iPhone just like the one I have in my 2nd Gen TL. Is it just as easy to install in the 3rd gen? Are there any guides on here that would help me out.
Thanks!
Thanks!
I think you can get to the connector you need if you remove the drive side panel covering the radio, check the 3g garage for a guide. Good luck though I tossed mine because it was garbage, loose pins kept messing up voice commands i think it was, same for another brand as well.
All I really need to know is what side the 14 pin connector is on. You mentioned the driver side panel, is that the only side I need to take apart?
I'm sure the center console trim and plastic under the steering wheel is similar to my second gen.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
ivegotthenav
09-11-2015 07:51 PM
