Blitzsafe Doesn't work.. Now what?
How may I help you.....?
Ok guys... I was working on the Doms install today and the Blitzsafe adaptor DOES NOT WORK.. (f-in piece of junk) I am looking into other options now and need some help... (yes i have searched...)
I know that the other two options are the PIE x3 and the USA Spec adaptor.. I wanted to use the Blitzsafe because it was plug n play... Are any of these other two options plug n play?
I am hoping that some people who have installed these can chime in here. I want to keep my XM and NOT have to splice into any wires....
Also, if any of these do work for what I want, would anyone have a model number by chamce? I can't seem to figure out the right thing to buy (already screwed up once and bought the wrong USA Spec from Circuit City and had to take it back...) I hate having a DVD palyer that has NO SOUND...
Thanks in advance for all the help...
Not sure if you are also looking to interface an IPod but I installed a PA11 – HON 2 and it works fine. I've got a non-navi TL and just hit DISC-5 to switch.
In order to keep XM, I had to also buy a Y-Adapter. No splicing at all.
It appears as though the 06TL has the same connections as my 04 Pilot.
Got mine here:
Interface - http://www.discountcarstereo.com/detail.aspx?ID=879
Y-Cable - http://www.discountcarstereo.com/detail.aspx?ID=787
Got mine here:
tried editing my post but ran out of time.
I went on to look a bit more and it appears as though there are issues with Navi vehicles. I guess since I don't have navi, I would contact them for details.
Both the USA Spec PA11-HON2 and PIE X3 are pretty much PNP.
The USA Spec just requires an additional Y-adapter to keep XM and it uses CDC emulation.
The PIX X3 requires an additional 12V power source, but it retains XM with the Honda harness that you will buy. The X3 uses an XM hijacking mechanism so you will see the XM titles display on top of the dash even though you're not using XM. Sound quality is great though.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I would have gone with USA Spec if it didnt have issues with the '06 TL. Now I have an extra aux-in with the X3. Oh well.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Thanks for the input. As I search around, there seem to be a few different things. There is a USA Spec I-pod interface and an USA Spec aux adaptor. I assume they work the same way, just the inputs are different. No matter where I look, I can not find anymore information about that y-adaptor for the USA Spec... any ideas??
For the PIE X3 is this the only cable I would need?? (outside of the actual module itself)
http://enfigcarstereo.com/shopsite_s..._X3_HON98.html
Thanks guys...
Thanks guys...
USA Spec AUX adapter? If you mean the DF-HON, that will not work. Just stick to the PA11-HON2.
As for the PIE X3,
other than the brain, you will need that harness to plug into the head unit (and allow you to keep XM).
I bought me X3 from myradiostore. Fast shipping and good price after tax and shipping. Actually, it was no tax and free shipping...
Good luck!
As for the PIE X3,
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Good luck!
Location: On the banks of a filthy river in east TX ruled by crooked cops, brazen women and pansexual cowboys.
Will the SoundGate SNHOND3 work?
SoundGate claims the device is compatiable with the TL's 04-06 but can't seem to find that much here on acurazine regarding the device.
Photo of SNHOND3.
Photo of SNHOND3.
OMGWTF4THGENTL
Jeff,
That sucks. No idea why it works in my car but not yours.
I'd go with the USA-Spec PA11-HON2. It work in the car without question, gives you an Ipod charger/interface and aux port. Only issue you MAY have is the USA-Spec use of Steering wheel control (apparently there's a bug thats' getting worked right now).
Mount the unit under the car seat or somewhere accessibel so you can remove it and send it back for a free upgrade when it's available.
J,
Check the soundgate application page again. The SNHON3 IS NOT COMPATIBLE with 04-06 TL's. The spec sheet references an FM transmitter.
J,
Photo of SNHOND3.
Photo of SNHOND3.
Doctor Sarcasm
Originally Posted by Kennedy
Jeff,
J,
J,
emailnatec
29
09-28-2018 04:27 PM
