the better place to mount the radar?
right above the dash or by the rear view mirror.
Escort radar detector. I have seen people mount it in both places, I want to put it in the better place while making sure its as concealed as possible.
^ the temporary solution till my hard wire kit with smart cord comes in
so where should it go?
I mounted my Escort 8500X50 near the rear view mirror, and have had good luck.
While it is probably best to have it in the center of your windshield, I think it is better to have it mounted higher instead of lower:
(1) The higher the detector sits on the windshield, the greater the "view" the detector has of the road ahead. Think of it like the difference you would have viewing the road ahead in a 18-wheel tractor-trailer vs. a Ferrari. This is made significantly worse if your detector is angled downwards (like it looks in your picture). Wherever you mount the detector, be sure that it is horizontally level and parallel with the centerline of your car (no yaw).
(2) While the TL's window tint won't reduce sensitivity of the radar reception (I don't believe that TL's windshield tint is metallic), but it may reduce the laser sensitivity a little. However, mounting the detector too low on the windshield may cause the windshield wipers to block the detector slightly, which will definitely reduce the radar sensitivity.
I hard wired mine and mounted it in the top left corner of the windshield next to the visor. You cannot see it from the outside and it's completely out of my way. This is just a temporary solution until my K-40 comes in.
How about the Escort SR-7 remote units. I have an older SR-1 in one of my other cars and it works well and now the SR-7's have a 'laser shifting' feature that seems even more interesting. Does anyone have one of these installed in their TL?
I did a search here and found nothing; Google search suggests the K-40 is a hidden combined radar-detector and laser-jammer with forward and rear operation. Why are you going this route? Does it work? Is it legal?
Narikin
Narikin
I have my Valentine1 mounted by the rearview mirror. The reason I did that is for reasons GotJazz mentioned, plus I thought it provides the detector a better "view" out the rear window. Someone correct me if I'm wrong in my assumption...
Originally Posted by narikin
laser-jammer....Is it legal?
Narikin
Narikin
-KeithT
I guess once the hard wire kit comes in, i'll try to mount it at the top, near the rear view mirror to see how distracting it is, otherwise i'll keep it where it is (it has no yaw gotjazz, its perfectly level) Is the hard wire kit long enough to go from there (the top near the mirror) all the way down to the fuse box?
The hard wire kit (with remote) is long enough - that's what I used. I had Best Buy install mine for about $25, which comes with a lifetime guarantee on the installation.
See my installation pictures here.
About the only problem I have experienced is that I can't get the windshield sunscreens over the detector, but I probably couldn't do that with the detector mounted anywhere useful.
I recently bought the Escort 8500 X50 and mounted it about 6 inches above the dash. Since it picks up signals behind, I wanted to make sure I had a clear shot out the back window as well. I would think that mounting it too high may block the rear detection. Depends on which detector you have, not all have rear sensing.
The problem with my mount is it's visible form front and behind, although it does sort or blend in with the quartz interior. Still have to take the damn thing off when parking in public places though!
Originally Posted by ¿GotJazz?
good install, i was wondering where i should put the smart cord unit.... I saw a previous post with it on the right side, but i think your install is better, I wish there was somehow i could integrate it into the center console without being too obtrusive
I was wondering guys if you could tell me how to put in the smart cord into the outlet. I can not fit smart cord into the outlet, the smart cord is to wide to fit in. :think:
Thanks.
There really is not enough difference in height on the windshield to make a lot of difference in reception. I have tried both high and low. The main reason for this is that you are not, hopefully, getting a clear shot at the radar transmitter but are picking up "scatter" from the cop taking readings on the folks in front of you.
Thanks for the info. Didn't these things come with a visor mount (vs the suction cup mount)?
Originally Posted by Mr. Re
edwards:
My fits in if I turn the cord so that the lights and mute button are upright(vertical) and not flat(horizontal). This should work for you as well.
-X-
edwards:
Mr. Re,
Thanks for your info, my apologies for replying so late. I will try it out tonight, but I remember that I try allots of ways and it still did not fit. I am worry about jamming it into there, and breaking somthing.
Originally Posted by mcmanut
Does anyone use the Solo S2 from Escort.( No cords to worry about) Do you like it?Thinking about buying one?
I had mine low on the center of the dash just high enough so that it was just above the wipers. Worked OK but was highly visible. I moved it to the lower left corner of the windshield. A round decal in front of the detector hides it completely, and it is an easy spot to hard wire. I was surprised that it still registered radar from the back. Lasar from the back; I don't know. By the way the radar guy that tests all radar detectors recommends having the detector as low as possible because of the narrow lasar path which may not reach the top of the windshield. Good luck.
You can make your own hard wire kit for the 8500 by simply snipping of one end of a telephone cord and wiring the red wire to the fuse block and the green to ground. It's a lot cheaper than the $10 plus shipping from Escort. I made mine from scratch for about $5 and 20 minutes effort (including installation).
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
