Best Instructions to use for iSimple PXAMG + the PGHHD1 Honda Install?
Old Feb 8, 2010 | 09:41 AM
WirelessRoute's Avatar
Unhappy Best Instructions to use for iSimple PXAMG + the PGHHD1 Honda Install?
I've been searching for about an hour now trying to find simple instructions on how to install the iSimple PXAMG + the PGHHD1 Honda/Acura harness that I purchased from group buy in my 2004 Acura TL with Navigation (AUTO). I found one post for that says I-058 which from 2008. The guy explains how to install without removing any parts of the dash, I am not sure if this applies to the kit I purchased. > https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-058-just-installed-peripheral-electronics-isimple-ipod-adapter-review-install-tips-697728/
Then I've seen a few post that have you remove your dash?
What is the best route to take for the install. I am going to attempt to do this tonight, if someone can post a link to best install for me to use I'd appreciate it
Old Feb 9, 2010 | 09:16 AM
Nevermind, I figured this out and did install. Took about an hour
Old Sep 25, 2010 | 05:54 PM
rzarezai's Avatar
Where did you have to install it? I have an 06 and the PAC support guy said it installs behind the dash in the 04-06. Is this true?
Old Sep 26, 2010 | 11:02 AM
Bucks13's Avatar
It goes behind the dash UNLESS you have XM NAV Traffic....in which case it would go in the trunk, connecting to the XM unit.
Old Sep 28, 2010 | 11:05 AM
Mug's Avatar
Mug
Here is a pic of my behind the dash install:
The connector is in the bottom corner on the driver's side of the car. If you don't want to contort your body in attempts to do this without removing the dash parts, it's not that hard.
Remove the silver trim pieces on both sides, remove the two screws at the bottom of the center storage bin, remove the lower panel above the pedals, remove the trim below the steering wheel, remove all the screws holding the trim along the side of the head unit. Now you can access the plug without pulling the whole head unit.
Another plus is that you can access the bottom of your storage bin. This way, you can run the plug up through and into the bin.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
bymotion
Nov 18, 2015 11:28 AM
Vejey Gandier
Sep 12, 2015 08:59 PM
EE4Life
Sep 11, 2015 10:13 PM
