Best 8 in free air sub-woofer??
looking for the best 8in free air sub-woofer on the market right now ..Ive searched but could not find much .going to use a 5 channel amp to on the sub and interior speakers...if i have to cut to make room for the fitment of the magnet not a big problem ...i know im going to dynamat it ..just want to know wat 8in free air sub will give me the best bass ...and i do NOT want to put a box in the trunk ...thanks
alot of the people i talked to liked this one KICKER CVT82 8" 400W
going to post this even thou you dont want a box
http://cgi.ebay.com/04-05-06-07-08-A...item4149f9f6eb
i have something similar in the rsx
http://cgi.ebay.com/ebaymotors/Custo...fAudioQ5fVideo
cheaper, id offer 225 to start. i have 500 rms watts on mine, does plenty without taking up my truck. just food for thought. ive also found much better clarity with a separate sub amp rather than have it draw off of your highs amp, regardless of wattage. but if you're going to be running a 50x4 +100x1 type 5 channel and a small free air, it probably wont be a big deal. i just dont see any free airs. my box is 0.65 cu/ft with an alpine type r 10
I am running the kicker 8 inch free air sub with dual 2 ohm voice coil. Also running a memphis 8 inch sub in a sealed enclosure. Added the kicker as I was not getting enough bass. Now it sounds like I have a 10 or 12 inch sub. The 8 in sealed gives me that tight bass. And the free air gives me the deeper bass I was looking for. Running a 200 watt alpine mono to both and running in series. Highly recommend this config. Rest of set up is focal separates front and rear and just using the stock amp to run the center channel. I am tempted to replace this. Have a 4x50 alpine to run the separates. Also have the ipod adapter.
DiamondJoeQuimby (11-09-2013)
Registered Bike Offender
I think the OP wants to increase the performance of his factory sub by just a bit. There's a plethora of knowledge regarding quality audio setups for the 3G TL and we all know that using the factory woofer location is stupid. But, is there a sub that could replace the factory one that would offer a moderate increase in performance without making it sound like rubbish? (Assuming an aftermarket amp is used and some felt is installed to reduce deck rattle)
Best free-air sub on the market?
^Bingo.
^Bingo.
SidhuSaaB
05-30-2020 12:40 AM
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
