Battery terminal to add amp?
My first ricer
So I've decided against messing with the stock sub, gonna remove it and install my Alpine MRP-M850 and 2 old MTX 12's I have that are taking up space in my house. Wiring will be 4 gauge I have a bunch of it lying around. I did search but couldn't find anything helpful, every car I had before was side terminal at the battery so I just added on ring terminals, but I'm looking for a top post terminal with a few outputs to replace the stock one. Can anyone post up what guage the stock battery cables are or what terminal they are using? I'm not planning on adding a 4 channel or any accessories anytime soon so I need a post 2 spots, one 4 gauge and one that will fit the stock positive cable.
i love these little things
http://www.abt.com/product/51959/JL-Audio-XDBTS.html
they are small and very secure on the terminals
if you need more connections just pick up a longer bolt at a hardware store
350 (02-11-2013)
I think the stock wireing is 4 and 2 gauge ( maybe ) . When i did my system , i bought all new terminals from Knu Konceptz . Cut all the old crusty battery clamps off and put the cables into the new ones and then connectedthe amp cable to that as well .
![](https://i41.photobucket.com/albums/e264/AlwayzSpoolin/A9565846-1C04-4DE7-AEDA-07DE29860745-2500-000002642FC4E28E_zps8cb749de.jpg)
You can see what i did with the stock cables on the battery post
My first ricer
My first ricer
So when I opened the JL terminal and looked at it, the opening is way too small for the stock battery cable, sucks I already opened the box. I wound up using a ring terminal on the stock terminal bolt, no issues.
there are plenty of ring terminals around (crimp, or crimp free, all kinds of sizes and shapes)
in 3 out 4 of these JL's that's what i ended up using
the hole in it can't take anything over 4
in some cars like my Ody there are 2 ground cables on the terminal, one of them small enough to go in the hole, the other needed a ring terminal
sorry it didn't work for you
MetalGearTypeS
08-29-2016 08:28 PM
soupi
14
11-15-2015 11:15 AM
