Battery
Old Sep 16, 2015 | 03:17 PM
cali boy 91's Avatar
Battery
My 05 tl keeps dieing over night, I checked my alternator with autozone and it checked out good but the battery was bad. I disconnected the HFL a long time ago so I doubt it is that. But once I jump start it and drive around it turns back on and off fine. I need help, what is killing my battery? Please!
Old Sep 18, 2015 | 11:41 PM
eastcoastguy's Avatar
So did you get another battery after the other one was found to be bad and the new one is dying as well? Sometimes batteries can be bad straight from the store. Check the posts to make sure there is no corrosion. Not sure what else could drain the battery.
Old Sep 19, 2015 | 06:45 AM
nj2pa2nc's Avatar
it's a car-drive it
Had same problem with my 06 tsx. Replaced the battery twice. If I did not use it for a few days it would not start. Even tho the alternator tested ok I had it replaced. No problems since then.
Old Sep 19, 2015 | 01:57 PM
lights's Avatar
Engineer
I have similar problem. I can't leave my car without running for around 8 hours, or my battery die. I pulled my HFL out as well a while back, same problem. If I keep my car active between the 8 hours, it'd be fine.....
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
steve
Sep 30, 2015 09:23 PM
mars
Sep 28, 2015 11:03 AM
jmaxima03
Sep 27, 2015 10:22 AM
