Auto/Night/Day lighting setting
Old Sep 22, 2004 | 11:26 PM
niarbdab's Avatar
Professional Somnabulist
In my TL, the Auto lighting function for the NAVI is not working. In Auto, it's always in Day mode.
Anyone else having this problem?
Old Sep 23, 2004 | 12:04 AM
rexwui's Avatar
You must have your cluster set on MAX. Simply press the < button and dim it one notch...that should fix the problem. It doesn't matter what setting you have the Nav at if you are in MAX mode - it will always be on the DAY setting if you are in MAX.
Old Sep 24, 2004 | 01:47 AM
niarbdab's Avatar
That did it! Thanks for the tip.
Old Sep 24, 2004 | 09:29 AM
1995hoo's Avatar
Keep Right Except to Pass
Note also that you can use the "MAX" button to switch back and forth--for example, if you are driving near dusk when you need your headlights on, but the night-time Navi display is too dark for the lighting conditions, just hit the "MAX" button and full brightness comes on. Then, when it gets darker outside and you want the night display, just hit "MAX" again and it will revert to the automatic setting. "MAX" acts as a toggle in this circumstance.
Old Mar 5, 2010 | 07:58 AM
1SLVRType-S's Avatar
6th Gear
Thanks for posting that fix. Dealer accidentally hit the button and I have spent a week trying to figure out what was wrong.
THANK YOU!!!!!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
braveheart
Sep 7, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
