Audio - Upgrade - TL
looks amazing! and spare tire access too!
QuickTL07 (10-28-2015)
awesome! Touch screen monitor? HDMI or what?
Yes that was my whole idea of a system, that I could get the spare tire out of the trunk if I ever needed too. The trunk isn't done yet, I still have few more things to do but its almost there. I would say 80%.. I will be putting led's around the amps, and protection mash fence around everything.
Also in process of building a sub box, that box that you see in the pic is a temporary one... I'm doing custom corner one.The sub is very massive.. I will need to make sure it has lots of support.
This monitor, it has a build in touch screen "digitizer" in front, so if you want to extend HDMI cable, you will have to buy it from them directly, " if you call the number ask for John" well the cable is like $20, that cable comes with usb connection right away. No drivers are needed for the monitor to work properly.. its plug and play.
QuickTL07 (10-29-2015)
Not done yet, still some work, it should be done before the winter.....
Thanks...
Sounds amazing, loud, clear, deep, centered, People reaction is priceless
Tomorrow I'm doing a demo at work on my lunch brake, he wants to hear some classical music.... Ground Zero 3 way setup better be up to its game, and my tuning !
Thanks...
The controls were kind of a PTA to do since I allready had the screen and wanted to make sure I could use it.
It takes time, but with time you could figure few things out, you will need to cut some things out, glue, and so on... If you want here is a link to everything I did to my car.
If you need any info,,, just simply ask. here is a link to my full build.
Build Log My New 07 Acura TL - Car Audio | DiyMobileAudio.com | Car Stereo Forum
I have redone the install of the monitor to make it more secure and to align everything.
Guiding pins to hold the monitor in place from the bottom
And this is how it look's now. All wires are behind, everything is connected without cutting any wires in the car. no wires have been cut that in this car.
Final Dash build.
Final Dash build.
QuickTL07 (11-06-2015)
QuickTL07 (11-17-2015)
Also it makes it look darker in the car, it draws less attention to others that have dirty hands.
Thanks for the kind words..
ReplayMan
10-28-2015 02:47 PM
Devon Peterson
10-21-2015 08:42 PM
