Audio out jack location
Old Jul 14, 2008 | 11:05 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
Just curious, where are you guys hooking up your amps? Where is the exact location of the connection, is it just a standard L/R, RCA audio out jack. I assume its behind the head unit in the dash.
Old Jul 14, 2008 | 11:56 AM
Stew4HD's Avatar
It's a lot more complicated than that. There are lots of threads on how to do it all over this portion of the forum.
Old Jul 14, 2008 | 12:19 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
1 search a minute isn't too user friendly though, at least when your at work. That would be great if anyone can help.
Old Jul 14, 2008 | 12:20 PM
bpham's Avatar
your gonna need a line output convertor or a high level input on your amp
Old Jul 14, 2008 | 12:33 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Thanks man. Looks like the my best option would be too run a quality output converter right behind the OE head unit to an amp in the trunk.
I'm thinking about upgrading the 8" and keep OE placement/looks/trunk space. I've read quite a few threads lately. Seems like the Kicker 8" from Crutchfield is good deal, even though a mounting adapter is needed. Any opinions on the Kicker so far?
Old Jul 14, 2008 | 12:55 PM
Stew4HD's Avatar
I took the signal after the factory amp (giving me a nice, high signal) and ran that to line out converters (2 - 4 input devices needed), then to the amps.
Old Jul 14, 2008 | 02:19 PM
csmeance's Avatar
This is the best route if you want to save money, but if you want to spend a little bit more have have better quality audio, drop the LOC's and get an AMP with high voltage inputs.
Old Jul 14, 2008 | 04:49 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
I know I sure have more to read on the subject. But, I thought you get a better quality sound by using a quality converter nearest to the source, to prevent noise. I would much rather connect to the OE amp to another amp.
Thanks for the comments everyone.
Any quality amp brand/model in mind w/ high voltage inputs? I was planning to get a 1 channel Alpine, just for the sub upgrade.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
