audio/dvd help!!!
Old Feb 12, 2009 | 12:49 PM
GET-MONEY's Avatar
5th Gear
audio/dvd help!!!
Hey I just put in 2 12's with amp in my trunk going to dynamat it but i now want to enhance the loudness of the my stock system.is there anyway to do this without replacing the stock nav unit?also not tryna spend a fortune something simple like maybe adding an amp or changing the interior speakers.(dont wanna lose the 5.1 surround sound)
thanks guys
Old Feb 12, 2009 | 05:07 PM
madpoz's Avatar
Changing the speakers alone won't make much difference, you need to change the amp out too. The challenge with keeping your 5.1 is that you need to find a way to power it. I have a 4 channel amp running the interior speakers, leaving the center channel on the factory amp. I have found that unless you're listening to a proper DVD-A disk, the 5.1 doesn't help the sound quality one bit. I turned the center channel off in the head unit, which cuts the music from the center without affecting the navigation or hands-free announcements.
Old Feb 12, 2009 | 05:26 PM
GET-MONEY's Avatar
5th Gear
Center speaker as in the factory sub or is there another speaker besides that one?I think I'm gonna get a 4 channel amp to power the other 4 speakers.what wattage is good to do that?
Old Feb 12, 2009 | 10:02 PM
csmeance's Avatar
thanks guys
what year is your TL? I suggest you go with a 1 4 channel amp and then another amp for your subwoofer.
Under the passenger kick panel is the factory amp, tap into the speaker wires (FR FL RR RL) and route them to your amp, use a Line output converter if your amp does not support high voltage inputs. Then set up your system like you would normally do.
As for your sub, disconnect the factory one, take it out, take the leads from that and send it to your amp for the subs, then to your subs.
Zonie
Aug 6, 2005 08:12 AM
