Attention JL 250/1 500/1 owners
jl audio has the speaker to rca cable for sale now on their website under audio accesories 12.95!! You use this cable to add a sub directly from the factory sub wires there is NO need for a loc or remote wire!! You can use this cable to run from the tl sub to the amp and not run a remote wire since the jl amps use signal sensing for turn on !!
Originally Posted by PeteThaPitbull
this will work on any JL amp? or jus 250/1 500/1 ?
I'm using a JL e1200, and it DOES require a switched power source to turn the amp on, but it also supports high level input. Just run the existing sub wires to the amp input.
Originally Posted by Kennedy
Sort of...
Lots of JL amps support line-level inputs...I'm running a 500/1 and a 350/4.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
