Anyone have Infinity Reference 6022i's???
Old Jul 5, 2010 | 10:26 AM
ParaSurfer1979's Avatar
Question Anyone have Infinity Reference 6022i's???
Just wanted to make sure things will clear after cutting away the speaker ring around the door panel. Thanks for your help.
Old Jul 5, 2010 | 11:13 AM
Here's stats:
Technical Specification
Woofer Composition: IMPP
Top Mount Depth: 1-7/8 Inches
Sensitivity: 93.4 dB
RMS Power Range : 2-60 Watts
Peak Power Handling: 180 Watts
Impedance: 2 Ohm
Frequency response: 53-21000 Hz
Diameter: 6.5 Inch
Design: 2 Way
Tweeter Composition: Textile
Features
2-way car speakers for 6-1/2" and 6-3/4" locations
Plus One+ injection-molded polypropylene (IMPP) woofer cone with hi-roll rubber surround
1" rotating UniPivot rotating textile dome tweeter column with ratcheting lock
Intermount III mounting system for fit in 6-3/4" openings
Extended motor structure for more bass
Edge-driven textile dome tweeter
Built-in tweeter level adjustment (0 or +3dB)
Priced per pair
Old Jul 5, 2010 | 08:35 PM
DeathMetal's Avatar
Fearless DIY Guy
Replacing the woofers isn't going to give you as great a return as the tweets. I upgraded my tweeters to 1031t model, WOW, what a difference. Just my $0.02
Old Jul 5, 2010 | 08:42 PM
Id think the added tweets in drs/rear as compared to the stock fullrange drivers would do just that.
Old Jul 5, 2010 | 09:10 PM
DeathMetal's Avatar
Fearless DIY Guy
Far from it. In a properly established system rear is for fill only, if not eliminated altogether and a full range in the doors is going to really f*ck your imaging up.
Old Jul 5, 2010 | 09:21 PM
Im aware of all of that. Im adding 2-ways for more clarity. I'm not looking for added vol or anything. I've had all hi-end stereo upgrades in my car but i trade cars so fast (every 2yrs), its just not worth it to me to go that far.
Old Jul 8, 2010 | 02:17 PM
saintsfan's Avatar
u can order them for 69.99 on the internet, i have them and yes the sound much better!! I also have a sub, but really if your not into the full system upgrade for 69 bucks you cant go wrong. All u need is some cutters or razor knife to cut some plastic!
Old Jul 8, 2010 | 08:35 PM
I found them even cheaper. I'm looking for added clarity. Thx for the help. I did the amps and sub swap im my 08 accord i tradecars too fast to spend that much again...lol.
Old Jul 9, 2010 | 12:17 AM
gotkilled's Avatar
NBP is a pain...
where did you find them for even cheaper than 69.89 parasurfer?
Old Jul 9, 2010 | 12:18 AM
gotkilled's Avatar
NBP is a pain...
also, i see that the new updated model is the the 6032cf. How come you didn't go w/ those?
Old Jul 9, 2010 | 12:20 AM
Names Desmond (see sig)...;-). A guy on Ebay sells them for 49.99/pr.
http://cgi.ebay.com/Infinity-Referen...80471343493938
Old Jul 9, 2010 | 12:23 AM
I havent ordered anything yet but the newer ones had no difference in stats and power handling. Don't think it would really matter anyway as im going to power off stock ELS amp. .
Old Jul 9, 2010 | 12:29 AM
gotkilled's Avatar
NBP is a pain...
haha thanks for link! i plan on powering them w/ the stock amp as well. i'm on the fence between the infinity 6.5 and the polk db651 6.5.
Old Jul 9, 2010 | 12:30 AM
gotkilled's Avatar
NBP is a pain...
btw, i think it's much cheaper on amazon or on google shopping/crutchfield since hte 6032 goes for a lil less than 70 shipped whereas the ebay link is 80 bucks shipped.
..that is unless you're local to the ebay seller and can pick it up in person
Old Jul 9, 2010 | 12:32 AM
Hes got kappas 62.9i for 64 bux a pr.
http://cgi.ebay.com/Infinity-Kappa-6...item19bdb8a094
Polks are 4ohm so if you got those using the stock 2ohm amp, you'll be loosing about 6db of volume.
Old Jul 9, 2010 | 12:50 AM
um you should email him. hes gonna do all 4 speakers shipped for 117.00. That trumps Amazon and the like.
Old Jul 9, 2010 | 10:34 AM
VmtSquad's Avatar
"Advance"
I just installed the Kappa 63.9i. They are a lot bigger then the 62.9i but they fit easily into our doors.
3-way speakers, 2ohm and I also have a small button to adjust the tweeter db level.
Will have to take a look at the tweeter now...and what you guys use for the 6/9 in the back?
Old Jul 9, 2010 | 11:41 AM
The rears are 6.5 also bro. Not 6x9's.
Old Jul 9, 2010 | 12:35 PM
VmtSquad's Avatar
"Advance"
^^Lol thanks for the info, I didnt begin looking for it since I'll wait to get the tweeter. So I guess I can drop in some 63.9i or the 3way tweeter wont fit ?
Old Jul 9, 2010 | 01:56 PM
no. put 3-way in back. Do 2-way in front so you can swivel the tweeter which cant be done with the three ways.
Old Jul 9, 2010 | 03:00 PM
VmtSquad's Avatar
"Advance"
^^I already insalled the 63.9i in the front and they are 3ways 2ohm, PLAY like crazy! Will probably install the same in the back... after I do the tweeter install in front
Old Jul 9, 2010 | 03:44 PM
unless you wanna cut a hole in the stock tweeter grill, aftermarket twweeters normally will not drop in cleanly. So for resale value, im leaving the tweeters how they are.
Old Jul 10, 2010 | 11:11 AM
ABP_04TL's Avatar
6-SPEED LOVER
i have infinity's... changin them tho, y? well they arent loud enough everytime i crank up my system speakers start to give that cracking sound past 30... they r good speakers but not capable of holdin a good amount of power.
Old Jul 10, 2010 | 11:14 AM
I don't follow what you just stated. Could you re-word exactly what you are explaining? Thanks...
quanaman
Jan 9, 2023 07:33 PM
baelim
May 10, 2018 09:53 AM
Tim Giron
Mar 18, 2016 09:50 PM
Juandiablo
Sep 27, 2015 10:32 AM
