Anyone Experience Rearview Camera Problems?
Old Aug 6, 2007 | 11:12 AM
slimmyjimmy's Avatar
Hello everyone,
I ordered a rearview camera from Wendy off of E-Bay about a year ago like most of the people on the forum who have had the rearview camera mod done and things were going great with it up until recently I started experiencing some major problems.
I had one of my installers install the camera itself so I'm having trouble pinpointing what the problem is.
Basically what happens is that sometimes when I shift the car into reverse, the camera kicks in, the image will be normal and a second or two later, the image gets all weird and distorted. Sometimes the screen turns black and grainy too. Also sometimes when I shift into reverse, the image won't even appear normal at all from the get go and will be nasty and distorted. These issues started to appear on an irregular basis for a while but now it pretty much happens everytime I'm in the car.
I believe that it could be a problem with one or more of these pieces.
1) Camera itself - becoming defective. If this is the case, anyone know if Wendy off of E-Bay covers issues like this?
2) Wiring becoming loose or defective.
3) Problem with Dom's video converter unit. I have a DVD player hooked up to the other video input and that works fine but the input that the camera is hooked up to might be having issues.
What do you guys think? Any help would be greatly appreciated.
Old Aug 6, 2007 | 11:53 AM
pikabb's Avatar
I've been having the exact same problems (can't describe it any better than you did!). I actually installed my camera myself, but I still can't pinpoint the problem. I think it might be where the camera wire plugs into the long wire that connects to Dom's box. This connection, for me, is made within the hinge of the trunk. When I take it apart it looks like the connection might be separating from using the trunk, so I am going to try relocating it higher up within the trunk lid itself. Problem is, even with the plastic hinges removed and the plug connection tight, it did not work perfect every time.
I know that didn't make much sense at all, but hopefully someone out there has a better answer!
Old Aug 9, 2007 | 10:08 AM
Anyone else have any feedback?
Old Aug 9, 2007 | 10:45 AM
Ac Man's Avatar
I'm having a grainy screen aswell, but that's the only problem so far. The screen is grainy sometimes, not all the time. I didn't install it so I don't know where to even look to find the problem. It's not a big deal YET!!! but most issues like these start out minor, and then get worse over time. I hope this is not the case with my camera.
Old Aug 9, 2007 | 12:15 PM
BrandonClaps's Avatar
loose power for Dom's unit??
you can try plugged the camera into the 1st input on dom's unit as well
Old Oct 20, 2007 | 06:37 PM
netinfiniti's Avatar
Same issues with "Wendy's" camera
Did anyone get this resolved, have identical problems and hooked up a TV monitor direct to the camera bypassing Dom's box. I think Wendy's camera is the culprit.
Suggestions for replacement welcome - Thanks
Old Oct 22, 2007 | 06:22 AM
acuratech25's Avatar
it is the camera itself we see that problem alot
Old Oct 22, 2007 | 07:55 AM
darksom1's Avatar
~Da Nocturnal Cheetah~
What about this for a possible replacement?
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=016
Old Oct 22, 2007 | 10:39 AM
Kennedy's Avatar
OMGWTF4THGENTL
That's a BIG camera.
I know jmbnova's Wendy camera failed too.
I think they're just cheaply made.
I think the "best camera" you could get would be the OE one.
Old Oct 22, 2007 | 10:56 AM
jmbnova's Avatar
How may I help you.....?
I also had issues with Wnedys camera. Just stopped working. It also was apparently NOT waterproof. I replaced it with this camera and have had no problems whatsoever. I think the picture quality is even better than Wendys and the way the TL is designed, it fits up under the trim pieces and is hard to see by someone just 'walking by'
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
Old Oct 22, 2007 | 01:38 PM
Kennedy's Avatar
OMGWTF4THGENTL
Hey Jeff,
Wouldja post a pic of it mounted, and a pic of your screen?
Can ya see the bumper (as a frame of reference) with that camera?
Old Oct 24, 2007 | 09:00 AM
Thanks for the tip, Wendy's camera failed in spite of sealing the edge with silicone as suggested by others - The OE Cam is nearly $600 though !!!
A pic when you have the time will be helpful to give us an idea...
Old Oct 24, 2007 | 10:03 AM
Chaddy0122's Avatar
Who-Dey!
Figures, I just bought Wendys camera for my 05 Accord coupe yesterday, GRRRR
Old Oct 24, 2007 | 10:09 AM
Doesn't she have a return policy that accepts unopened items?
Old Oct 24, 2007 | 10:49 AM
Chaddy0122's Avatar
Who-Dey!
just says exchange on the ebay listing
Old Oct 24, 2007 | 04:38 PM
Kennedy's Avatar
OMGWTF4THGENTL
Relax... People only post when they have a problem wth the Wendy cam. It's not like all of them are failing.
Mine's going 18 months strong.
Key rule, NO high pressure water on the rear of the car. NO auto mated car washes... and most importantly of all, NO dealer washes (which is usually a combination of both above).
Old Oct 25, 2007 | 02:38 AM
darksom1's Avatar
Where are you with those pics Jeff? I just bought the Dice, going to buy the navtv2go thing, and this is next. I need a proven camera. You local guys know Dennis lives a ways from Germantown! So no mistakes allowed!
Old Oct 25, 2007 | 03:49 PM
datmrman's Avatar
Mine has been working like the day I installed it.
I'm knocking on wood now so that I don't jinx myself.
Old Oct 25, 2007 | 04:15 PM
lembowski's Avatar
Trucki!!
Mine works fine.
But it has on occasion made that weird almost neon looking distorted looking lines around things. Its done this once or twice since I've had it. Nothing for the past few months....
Old Oct 29, 2007 | 10:26 PM
solislbc's Avatar
i'm having this problem on occassion. has anyone attempted to contact Wendy? does anyone remember her ebay screen name?
Old Oct 30, 2007 | 09:54 AM
jmbnova's Avatar
My fault, I completely shit the bed on this one. I will get a picture of the camera up tonight.
Old Oct 30, 2007 | 01:37 PM
I looked into this camera and it looks like YESCOMUSA is still selling them for around $75. It comes in both a silver and black color option. If you look at the auction more closely, there are pictures of both on there.
I think it needs to be set on the upper part of a license plate frame though. So what I think I'll be doing is getting a silver license plate frame and install the camera on top of there. I ordered the silver camera today. I think the black might look a little out of place and might be a bit more noticeable than the silver. I might be wrong about this so I'm hoping I made the right choice
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
bymotion
Nov 18, 2015 11:28 AM
