Android Set Brightness & Settings by Sunrise/Sunset GPS data
Old Oct 24, 2014 | 04:38 PM
mzilvar's Avatar
I can't take full credit for this, much of it was taken from the Tasker Wiki here:
Sunrise and Sunset times - Tasker Wiki
I have, however, modified it slightly to use earthtools and also to use GPS to determine your location vice using an internet connection. Here's what it does, the pre-requisites and how to use it.
Disclaimer
I accept no responsibility whatsoever for any harm, damage or anything otherwise that the script included may cause. Additionally I provide no warranty, express or implied of any type. The code is free to use, as you see fit.
What is this?
A script that is used from Tasker on a rooted android device to fetch the sunrise and sunset times for your location, determined by GPS, from the internet and write them to a Google calendar.
This is for use on any Android in-dash tablet install or other Android device where you might find these functions useful.
Once this data is written to a Google calendar, we can use another script to read that data and can perform a whole host of functions based upon the GPS-based sunrise and sunset times for your location including:
- Alter the tablet manual brightness settings
- Change your wall-paper
- Enable night-mode settings
- Anything else you can do from tasker that you might want to do after sunset
- There are some extra tasks that in the script that are not needed, like one to create a 'Reboot' button and one for a 'Reboot to Recovery' button. If you don't need these just delete the tasks out of Tasker. This is taken off my tablet and are a few extra things I was using.
- 'Sun Data', 'Sun Calendar', 'Day Settings' and 'Night Settings' are the ones that work the magic
Pre-Requisites
- Rooted tablet
- Android based device
- Tasker App installed from Play store
- A Google calendar named 'Tasker'
Optional
- Tasker Helper
- Secure Settings (required for some of the tasks included in the xml, though not the Sunrise/Sunset times tasks)
- Link to the ROM I'm using for Nexus 7 (V) 1 only --> AutoDroid http://forum.xda-developers.com/show....php?t=2789993 (kernel is included with ROM now, he's updated past where I was at in the video)
How to use it
Before Proceeding backup your current Tasker profiles to an xml file, in case there is a conflict between two of them and one of yours gets over-written or altered. If it does you can remove the tasks in conflict and restore your original profiles to add them back in.
- Copy the code in the code section below.
- Paste it into a new text file
- Name the file to your desire and change the .txt extension to .xml
- Transfer this file to your android device and place it in /sdcard/tasker/profiles
- From tasker, long press the profiles tab and press import
- Import the xml file
Important Notes
- You MUST create a calendar named 'Tasker' exactly in order for this to work with the script as-is. You can alter the script to change the calendar name and then create a Google calendar named whatever you like, so long as it matches what is in the script.
- Check your time-zone settings on your Google calendar, this can throw off the sunrise/sunset times if it's improperly set.
- Alter the profile that runs it automatically to a time when you'll be in your car with your phone tethered so there's an internet connection
- Alternatively you can create a button somewhere and press it to fetch the sunshine data and then press another button to write that data to the sun calendar using the tasks themselves.
- This fetches the sunrise/sunset times for the NEXT day, not the CURRENT day, so you must run it the day prior, either automatically while your phone is connected or manually by running the tasks themselves
- There are extra tasks the script will add to tasker, if not needed simply delete them or change them to your heart's desire.
Video of it Running
So where's the code? (Sorry AZ won't let me use the code blocks.)
<TaskerData sr="" dvi="1" tv="4.4u3m">
<Profile sr="prof12" ve="2">
<cdate>1404954462625</cdate>
<edate>1407359886633</edate>
<flags>18</flags>
<id>12</id>
<mid0>10</mid0>
<mid1>11</mid1>
<nme>Sunshine</nme>
<State sr="con0" ve="2">
<code>5</code>
<Str sr="arg0" ve="3">Daytime</Str>
<Str sr="arg1" ve="3"/>
<Str sr="arg2" ve="3"/>
<Int sr="arg3" val="0"/>
<Str sr="arg4" ve="3">Google:Tasker</Str>
</State>
</Profile>
<Profile sr="prof13" ve="2">
<cdate>1407203812433</cdate>
<edate>1409111041312</edate>
<flags>2</flags>
<id>13</id>
<mid0>14</mid0>
<code>10</code>
<pin>true</pin>
<Int sr="arg0" val="0"/>
</State>
</Profile>
<Profile sr="prof5" ve="2">
<cdate>1405808984151</cdate>
<edate>1409111058336</edate>
<flags>2</flags>
<id>5</id>
<mid0>6</mid0>
<code>10</code>
</State>
</Profile>
<Profile sr="prof9" ve="2">
<cdate>1404954386303</cdate>
<edate>1409182906425</edate>
<flags>16</flags>
<id>9</id>
<mid0>7</mid0>
<mid1>8</mid1>
<nme>Sunshine - Check</nme>
<Time sr="con0">
<fh>7</fh>
<fm>0</fm>
<th>7</th>
<tm>1</tm>
</Time>
</Profile>
<Project sr="proj0" ve="2">
<cdate>1404078747474</cdate>
<mdate>1407203878127</mdate>
<name>Base</name>
<pids>9,12,5,13</pids>
<tids>7,8,10,11,2,3,6,4,14</tids>
<Img sr="icon" ve="2">
<nme>hl_aaa_ext_home</nme>
</Img>
</Project>
<Task sr="task10">
<cdate>1404954462615</cdate>
<edate>1409767639345</edate>
<id>10</id>
<nme>Day Settings</nme>
<pri>10</pri>
<Action sr="act0" ve="6">
<code>808</code>
</Action>
<Action sr="act1" ve="6">
<code>989</code>
</Action>
<Action sr="act2" ve="6">
<code>810</code>
<Int sr="arg0" val="122"/>
<Int sr="arg1" val="0"/>
<Int sr="arg2" val="0"/>
</Action>
<Action sr="act3" ve="6">
<code>109</code>
<Str sr="arg0" ve="3">Download/whiteslm.png</Str>
</Action>
<Img sr="icn" ve="2">
<nme>hl_rating_important</nme>
</Img>
</Task>
<Task sr="task11">
<cdate>1404954462613</cdate>
<edate>1407814600154</edate>
<id>11</id>
<nme>Night Settings</nme>
<pri>10</pri>
<code>808</code>
<Int sr="arg0"/>
</Action>
<code>989</code>
<Int sr="arg0" val="1"/>
</Action>
<code>810</code>
<Int sr="arg0" val="30"/>
<Int sr="arg1"/>
<Int sr="arg2" val="1"/>
<Int sr="arg3" val="1"/>
</Action>
<code>109</code>
<Str sr="arg0" ve="3">Download/bluslm.png</Str>
</Action>
<nme>hl_rating_not_important</nme>
</Img>
</Task>
<Task sr="task14">
<cdate>1407203825065</cdate>
<id>14</id>
<nme>Kill Apps</nme>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Airplane Mode Enabled</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. BLURB-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.B LURB-type>
<com.intangibleobject.securesettings.plugin.extra. ENABLED>true</com.intangibleobject.securesettings.plugin.extra.E NABLED>
<com.intangibleobject.securesettings.plugin.extra. ENABLED-type>java.lang.Boolean</com.intangibleobject.securesettings.plugin.extra.E NABLED-type>
<com.intangibleobject.securesettings.plugin.extra. SETTING>airplane_mode</com.intangibleobject.securesettings.plugin.extra.S ETTING>
<com.intangibleobject.securesettings.plugin.extra. SETTING-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.S ETTING-type>
<com.twofortyfouram.locale.intent.extra.BLURB>Airp lane Mode Enabled</com.twofortyfouram.locale.intent.extra.BLURB>
<com.twofortyfouram.locale.intent.extra.BLURB-type>java.lang.String</com.twofortyfouram.locale.intent.extra.BLURB-type>
<net.dinglisch.android.tasker.subbundled>true</net.dinglisch.android.tasker.subbundled>
<net.dinglisch.android.tasker.subbundled-type>java.lang.Boolean</net.dinglisch.android.tasker.subbundled-type>
</Vals>
</Bundle>
<Str sr="arg1" ve="3">com.intangibleobject.securesettings.plugin </Str>
<Str sr="arg2" ve="3">Secure Settings</Str>
</Action>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>GPS Disabled</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. ENABLED>false</com.intangibleobject.securesettings.plugin.extra.E NABLED>
<com.intangibleobject.securesettings.plugin.extra. SETTING>gps</com.intangibleobject.securesettings.plugin.extra.S ETTING>
<com.twofortyfouram.locale.intent.extra.BLURB>GP S Disabled</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Location Mode/Location Off</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION>0</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION-type>java.lang.Integer</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION-type>
<com.intangibleobject.securesettings.plugin.extra. SETTING>location_mode</com.intangibleobject.securesettings.plugin.extra.S ETTING>
<com.twofortyfouram.locale.intent.extra.BLURB>Loca tion Mode/Location Off</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
</Task>
<Task sr="task2">
<cdate>1405025734038</cdate>
<edate>1405025820690</edate>
<id>2</id>
<nme>Reboot</nme>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Reboot</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION>REBOOT</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION-type>
<com.intangibleobject.securesettings.plugin.extra. SETTING>reboot</com.intangibleobject.securesettings.plugin.extra.S ETTING>
<com.twofortyfouram.locale.intent.extra.BLURB>Rebo ot</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<nme>hd_navigation_refresh</nme>
</Img>
</Task>
<Task sr="task3">
<cdate>1405025831967</cdate>
<edate>1405025870580</edate>
<id>3</id>
<nme>Recovery</nme>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Reboot Recovery</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION>REBOOT_RECOVERY</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION>
<com.twofortyfouram.locale.intent.extra.BLURB>Rebo ot Recovery</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<nme>hd_images_rotate_left</nme>
</Img>
</Task>
<Task sr="task4">
<cdate>946705436924</cdate>
<edate>946705571035</edate>
<id>4</id>
<nme>Shutdown</nme>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Shutdown</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION>SHUTDOWN</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION>
<com.twofortyfouram.locale.intent.extra.BLURB>Shut down</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<nme>hd_aaa_ext_halt</nme>
</Img>
</Task>
<Task sr="task6">
<cdate>1405808993754</cdate>
<id>6</id>
<nme>On</nme>
<pri>10</pri>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Keep Display On: AC, USB</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION>3</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION>
<com.intangibleobject.securesettings.plugin.extra. SETTING>display_charge</com.intangibleobject.securesettings.plugin.extra.S ETTING>
<com.twofortyfouram.locale.intent.extra.BLURB>Ke ep Display On: AC, USB</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Airplane Mode Disabled</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.twofortyfouram.locale.intent.extra.BLURB>Airp lane Mode Disabled</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>GPS Enabled</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.twofortyfouram.locale.intent.extra.BLURB>GP S Enabled</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra. BLURB>Location Mode/Device Only</com.intangibleobject.securesettings.plugin.extra.B LURB>
<com.intangibleobject.securesettings.plugin.extra. EXTRA_SPINNER_OPTION>1</com.intangibleobject.securesettings.plugin.extra.E XTRA_SPINNER_OPTION>
<com.twofortyfouram.locale.intent.extra.BLURB>Loca tion Mode/Device Only</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
</Task>
<Task sr="task7">
<cdate>1404954386277</cdate>
<edate>1413001529528</edate>
<id>7</id>
<nme>Sun Data</nme>
<pri>10</pri>
<code>902</code>
<Int sr="arg1" val="30"/>
</Action>
<code>590</code>
<Str sr="arg0" ve="3">%LOC</Str>
<Str sr="arg1" ve="3">,</Str>
</Action>
<Action sr="act10" ve="6">
<code>547</code>
<Str sr="arg0" ve="3">%Sunset</Str>
<Str sr="arg1" ve="3">%DATE %HTTPD012</Str>
<Int sr="arg2"/>
<Int sr="arg3"/>
</Action>
<Action sr="act11" ve="6">
<code>549</code>
<Str sr="arg0" ve="3">%HTTPD+</Str>
<Int sr="arg1" val="1"/>
</Action>
<Action sr="act12" ve="6">
<code>549</code>
<Str sr="arg0" ve="3">%LOC2</Str>
<Int sr="arg1"/>
</Action>
<Action sr="act13" ve="6">
<code>549</code>
<Str sr="arg0" ve="3">%LOC1</Str>
<Int sr="arg1"/>
</Action>
<Action sr="act14" ve="6">
<code>549</code>
<Str sr="arg0" ve="3">%DATE+</Str>
</Action>
<Action sr="act15" ve="6">
<code>596</code>
<Str sr="arg0" ve="3">%Sunrise</Str>
<Int sr="arg1" val="3"/>
<Str sr="arg2" ve="3">%SunriseMin</Str>
</Action>
<Action sr="act16" ve="6">
<code>596</code>
<Str sr="arg2" ve="3">%SunsetMin</Str>
</Action>
<Action sr="act17" ve="6">
<code>548</code>
<Str sr="arg0" ve="3">Sunshine Data retrieved for %LOC
%Sunrise - %Sunset</Str>
</Action>
<code>590</code>
<Str sr="arg0" ve="3">%DATE</Str>
<Str sr="arg1" ve="3">-</Str>
<Int sr="arg2"/>
</Action>
<code>118</code>
<Str sr="arg0" ve="3">www.earthtools.org</Str>
<Str sr="arg1" ve="3">/sun/%LOC1/%LOC2/%DAYM/%DATE1/99/1</Str>
<Str sr="arg3" ve="3"/>
<Str sr="arg4" ve="3"/>
<Int sr="arg5" val="12"/>
<Str sr="arg6" ve="3">text/xml</Str>
<Str sr="arg7" ve="3"/>
<Int sr="arg8" val="0"/>
</Action>
<Action sr="act4" ve="6">
<code>547</code>
<Str sr="arg0" ve="3">%HTTPD0</Str>
<Str sr="arg1" ve="3">%HTTPD</Str>
<Int sr="arg2"/>
<Int sr="arg3"/>
</Action>
<Action sr="act5" ve="6">
<code>590</code>
<Str sr="arg1" ve="3">&lt;/sunrise&gt;</Str>
<Int sr="arg2"/>
</Action>
<Action sr="act6" ve="6">
<code>590</code>
<Str sr="arg0" ve="3">%HTTPD01</Str>
<Str sr="arg1" ve="3">&lt;sunrise&gt;</Str>
<Int sr="arg2"/>
</Action>
<Action sr="act7" ve="6">
<code>547</code>
<Int sr="arg2"/>
<Int sr="arg3"/>
</Action>
<Action sr="act8" ve="6">
<code>590</code>
<Str sr="arg1" ve="3">&lt;/sunset&gt;</Str>
<Int sr="arg2"/>
</Action>
<Action sr="act9" ve="6">
<code>590</code>
<Str sr="arg1" ve="3">&lt;sunset&gt;</Str>
<Int sr="arg2"/>
</Action>
<nme>hd_device_access_brightness_high</nme>
</Img>
</Task>
<Task sr="task8">
<cdate>1404954386281</cdate>
<edate>1405805174992</edate>
<id>8</id>
<nme>Sun Calendar</nme>
<pri>10</pri>
<code>547</code>
<Str sr="arg0" ve="3">%DAYSTART</Str>
<Str sr="arg1" ve="3">%SunriseMin / 60 - %TIMES / 60</Str>
<Int sr="arg3"/>
</Action>
<code>547</code>
<Str sr="arg0" ve="3">%DAYLENGTH</Str>
<Str sr="arg1" ve="3">%SunsetMin / 60 - %SunriseMin / 60</Str>
<Int sr="arg3"/>
</Action>
<code>547</code>
<Str sr="arg1" ve="3">%DAYSTART + 1440</Str>
<Int sr="arg3"/>
<ConditionList sr="if">
<Condition sr="c0" ve="3">
<lhs>%DAYSTART</lhs>
<op>6</op>
<rhs>0</rhs>
</Condition>
</ConditionList>
</Action>
<code>590</code>
<Str sr="arg1" ve="3">.</Str>
<Int sr="arg2"/>
</Action>
<code>590</code>
<Int sr="arg2"/>
</Action>
<code>567</code>
<Str sr="arg0" ve="3">%DAYSTART1 / %DAYLENGTH1</Str>
<Str sr="arg1" ve="3">Google:Tasker</Str>
<Str sr="arg2" ve="3">Daytime</Str>
<Int sr="arg5"/>
<Int sr="arg6" val="0"/>
</Action>
<code>549</code>
<Str sr="arg0" ve="3">%DAY*</Str>
</Action>
<code>549</code>
<Str sr="arg0" ve="3">%SunriseMin</Str>
<Int sr="arg1"/>
</Action>
<code>549</code>
<Str sr="arg0" ve="3">%SunsetMin</Str>
<Int sr="arg1"/>
</Action>
<code>548</code>
<Str sr="arg0" ve="3">Sunshine Data saved to Calender</Str>
</Action>
<nme>hd_content_event</nme>
</Img>
</Task>
</TaskerData>
Old Oct 24, 2014 | 05:05 PM
triax37's Avatar
Cool. Thanks for sharing and the great writeup!
Old Oct 27, 2014 | 12:02 PM
Adobeman's Avatar
The DVD-A Script Guy
That's quite a bit of moving parts! But if it works....
Is the light sensor obstructed or not on your Nex? I can't tell from the pictures. If it isn't you may want to try an app called Velis Auto Brightness. I use it on my phone and it's been pretty good. Typically the auto brightness curves in most ROMS leave a bit to be desired but what you might find interesting about this one is you can set the curve your self and you can also set many other variables like ramp down and up delays, smoothing time delays, and many other thresholds. Typically auto brightness doesn't work so good in a car because the light levels at the center console areas often "disagree" with what you see. But I'd imagine you could set up a curve and response delay times and thresholds that would work pretty good.
I don't have anything to do with the app. I just use it and thought you might be interested. It also has some support for Tasker (as an IAP) but I never tried that. I use Llama for all my automation, not Tasker.
Old Oct 27, 2014 | 12:29 PM
CrazyEights's Avatar
So not a sociopath
Is the brightness sensor blocked?
If not Lux auto brightness is great for doing what you want without the complication, but that's a great writeup regardless.
Old Oct 27, 2014 | 04:47 PM
mzilvar's Avatar
I'm pretty sure my light sensor is next to the camera if I'm not mistaken both of which are covered by the plastic bezel in my car so it shouldn't pick up much if anything.
That's why I'm using manual brightness, I enjoy messing with this a bit anyhow and it has the added feature that the time is adjusted automatically throughout the year since it's pulling it from the web.
If I wasn't selling my car soon I'd try messing with the script to get it to write a month or year at a time of sunrise/sunset times to the calendar so it doesn't have to pull it from the web every day, only time that would be off then is if you crossed time zones though.
Old Oct 27, 2014 | 07:21 PM
NoRice91's Avatar
3rd Gear
Nice looks good!
rockyboy
Aug 4, 2024 10:35 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
johnalfa
Oct 31, 2015 12:55 PM
braveheart
Sep 7, 2015 08:12 AM
