Amp won't turn on (bare with me, NOOB)
9 mpg.
Ok so I took out my sub and amp to shed some weight before I raced a friend and I had the ingenious idea to re-connect my stock sub so I could have some "bump". So while trying to reconnect my stock sub, I had to disconnect my LOC which was attached to the wiring of the stock sub by metal clips/brackets. I don't really know how to explain it.
- Anyways, yesterday my amp would turn on but the sub wouldn't. and today my amp won't even turn on, period. I was pretty rough with the Line out converter. Anything I can do to troubleshoot and find out what's really wrong? I know it's not the stock wiring because I reconnected it to the stock sub and it was hitting fine but when I try to reconnect it to the LOC, it doesn't work at all.
*SORRY IF THIS IS VAGUE. I'm not that familiar with car audio.
check the power wire for the amplifier and see if you can turn it on. Be sure to also check the inline fuse that should be connected along the power wire. (should be near the battery on the wire that leads to power the amp). Also check your grounds and make sure they are fastened securely on bare metal.
9 mpg.
"Ok so I took out my sub and amp to shed some weight before I raced a friend "
How much does this box weigh?
Did you reconnect the RCA cable going from the amp to the LOC?
mada51589
05-03-2022 08:54 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
Pegon95
09-15-2015 01:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
