Amp Power Cable
Amp Power Cable
I have an 07 tl type s with manual transmission and I'm installing an aftermarket alpine amp I already have have all the wires tapped and set besides the power cable.
i ran the power cable a 0/1 awg from the trunk to the dead pedal up front and I'm stuck there i can't see the rubber boot to pass it through the firewall. I've searched all over the internet and seen YouTube videos and I see the boot on tl automatic transmission but not on my car which has a manual transmission. I've read some comments that it's different on manual cars from an automatic but I'm not sure.
Anyone with a manual transmission TL has pass through a power cable through the firewall or how did you run a amp power cable to the battery?
Please help I'm stuck at this point.
where would that hole be located under the dash because I already ran the power cable to the trunk so I have to fish it under the dashboard to the engine bay?
behind the center console, hard to explain. just push something random through the engine bay direction and you'll easily see where it pops out inside the car
ok thanks man, I was able to fish it with another cable and attached it with tape and then pulled it.
it was behind the nav/radio
