Amp location???
Old Feb 19, 2008 | 01:37 PM
TLAdvanced's Avatar
The Kinetics of Bleu
Amp location???
I am going to install my amp and sub next week. I got a fiberglass box from ebay CAS http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=022 My question is does anyone have any good suggestions on where to put the amp?? I want to keep it looking as factory as possible, and keep as much trunk space as possible. Thanks for the help!!!!
Old Feb 20, 2008 | 01:48 AM
TLAdvanced's Avatar
No ideas???
Old Feb 20, 2008 | 02:43 AM
datmrman's Avatar
The cleanest looking place, although not the most practical, is where the spare is. It looks great, but sucks when you have a flat.
Old Feb 20, 2008 | 01:06 PM
Spiritman's Avatar
Man of God.....
Cool
I put mine under the drivers seat. Xtant 3.1
Take a read on it.
https://acurazine.com/forums/ramblings-12/triathlon-145417/
Old Feb 20, 2008 | 01:19 PM
Fulani has a TL's Avatar
Which amp you installing, Cuz I think it was kennedy who installed the amp within the spare trunk, removed the foam and it fit in perfectly. I tried with a JL 500/1 but its too big, so Mine has been just chillin in the trunk for like the last year and a half
Old Feb 20, 2008 | 02:50 PM
mrlunecy's Avatar
312 HP 271 TQ Dynapack
I think this is what you're looking for;
1/2 inch wood board drilled to the trunk frame, right behind the back seat. This is my set up. Optimal trunk space, easy to remove the sub box, and STILL got my spare! Only this was A LOT of work. Any random stereo shop will just drill your amps straight to your back seat, SO BE CAREFULL if you chose not to do it yourself!
Old Feb 20, 2008 | 05:26 PM
ron_c1's Avatar
Completely out of sight - lose the spare or put it under one of the front seats if it will fit..
Mostly out of sight - build a rack in the opposite corner of the sub with a cover to enclose the rack and dvd rom drive or build a rack that attaches to the bottom of the rear deck..
Old Feb 20, 2008 | 06:58 PM
VIP-A-SPEC's Avatar
REDONDO RED
I have mine on the back of the box. The only down side is if you want to pull the box out, you have to unhook all the wires. However, it keeps it looking clean and uncluttered.
Old Feb 20, 2008 | 11:21 PM
King of Pain's Avatar
You can do this. I lost about 3 inches from the floor where the amps are placed and I still have access to my spare. I still have a little bit of work to do on it before it's 100% done
Old Feb 20, 2008 | 11:44 PM
TLAdvanced's Avatar
Thanks for all the ideas guys. King of Pain, that looks AWESOME!! I think I might try to see if I can make something to fit in where the foam in in the spare. The thing is I am afraid it won't get any air down there and will overheat. What do you guys think??
Old Feb 21, 2008 | 11:25 AM
mrlunecy's Avatar
Dammm, Pain!!! That's a clean-ass install!! Thanks for making mine look like ass!!!
hahaha. But seriously, that looks sharp without sacrificing much trunk space. How do you get to the spare? Can you pop it open and snap a picture?
TL advance,
As long as your amp has some open air, you should be alright with dissepating (spell check) the heat. Unless you plan on soundbombing the entire time you drive. Most descent brand amps run pretty efficiently and don't generate as much heat. But then again you can always run CPU fans, like I had in my gen2 TL.
This is a pic after I stripped it, before selling it... It was like breaking up with a girlfriend of 2 years and asking for my teddy bear back. lol!
Just something to think about, if you go that route.
Old Feb 21, 2008 | 11:43 AM
TLadvanced, what amp you planning on running?
Like Mrlunecy said, if you running a good quality amp you don't have to worry about the heat, unless you tryin to drive with the sub level at full, and bass level at full.... How def and numb you wanna get?!
Old Feb 21, 2008 | 12:54 PM
Here's how I get to the spare.
Take off the beauty board:
Pull up on the amp Rack
There's the spare
Old Feb 21, 2008 | 01:16 PM
TLAdvanced's Avatar
I am planning on running an audiobahn A8000T amp. Good advice guys, that's why I love Acurazine!!!
Old Feb 21, 2008 | 09:22 PM
mrlunecy's Avatar
That's some Professional show quality sh!t right there, Pain! Everything is clean-cut and perfect! Where'd you get that done? And (if you don't mind me asking) what's the price of an install like that?
Thanks for the quick response.
Old Feb 22, 2008 | 09:13 AM
I did it myself. I do all my own audio installs.
I'll start my own thread later when I'm 100% done. I want to make some small changes to the trunk and improve the imaging on the front speakers. It's built for SQ. I like the look and space saving advantages of side mounted subs but I feel that the best SQ come from centered rear firing subs.
Old Feb 22, 2008 | 11:14 AM
mrlunecy's Avatar
Well, good freakin work, man! I look forward to seeing your future work.
Old Feb 22, 2008 | 11:48 AM
Tripnbeats's Avatar
king has some serious amps! those alpines are insane
Old Feb 22, 2008 | 12:06 PM
It won't fit within the spare tire
Old Feb 22, 2008 | 12:22 PM
TLAdvanced's Avatar
Well, I changed my mind on amps. I'm gonna run a Bazooka BA1500 mono 500W RMS amp, and 1 12" Infinity Perfect single voice coil. I hope they will work well together . I can't find specs on the sub. It is a few years old, and most of the new Infiniti Perfect subs are DVC. My question is this: If the Baooka amp makes 500RMS @ 2 ohm's will the Infiniti run @ 2 ohms as well? Also, does anyone know how to wire the amp to work off the factory stereo's sub gain control on the navi screen??
Old Feb 22, 2008 | 05:49 PM
gynuine69's Avatar
I agree. Datmrman, where do you have your amp installed? any suggestions on where I can find more information on how to mount an amp in the spare tire compartment?
Old Feb 22, 2008 | 06:01 PM
gynuine69's Avatar
I wish i would have scrolled down lower before my first post. King of Pain... PLEASE keep me posted when this thread is put up. I would LOOOOOOOOOOVE to know how you did the spare tire amp compartment set up. I am looking to run a Diamond Audio 600x1 mono block and want that exact same look. I've had this stuff just sitting in my trunk for months and need to pull the trigger. That lil stock 8inch sub just aint doing it for me at all!
how long did it take you to create the actual compartment set up? What material did you use? share your words of wisdom!!!
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
