Memo button not working -> cannot store new memory seat
Old 06-12-2015, 12:34 PM
3rd Gear
tcao2's Avatar
Hello all,
I have a 2006 Acura TL. Recently, I cannot save new memory seat anymore. The "memo" button does not work at all when I press it (no sound, no light). The other button (seat 1 and seat 2 button next to the memo button) works just fine. Whenever I tried to save a new seat position, I change the seat to the desired position, press the memo button (nothing happens), then press either of the "1" and "2" button to save it. It does not save, and just go back to the previously stored seat position.
I read some other threads regarding the mirror actuators and windshield washer, but those works fine on my car. Everything is fine except for that. I tried re-linking the keys too, but it still does not work. Anyone have any idea what's going on? Thank you so much in advance!
Old 06-13-2015, 06:14 AM
JMiles_T's Avatar
I have a similar problem with my TL. I think it's an issue with the memory module which is located under the driver's seat.
See the link at the top here
Old 06-13-2015, 08:48 AM
3rd Gear
tcao2's Avatar
Thanks for the reply. Have you tried that method?
Old 06-13-2015, 02:14 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
The memory seat module is the problem for most 2004 TLs.
I haven't heard anything wrong with them for 2006.
I believe they fixed the issue with the module in 2005.
I would attempt to disconnect the battery and reconnect it again after a few minutes.
Old 06-19-2015, 06:45 PM
3rd Gear
tcao2's Avatar
Thanks for the input. I tried disconnecting the battery for a few mins as your suggestion, but the problem is still there. Any other idea? I don't wanna bring this to a shop and let them charge crazy amount on it just to look into the problem
Old 11-24-2019, 09:30 PM
Chad05TL's Avatar
Old thread. U just encountered the memory buttons do not work if I unlock the car with my remote.. but when I insert the key and turn it to accessory, then the light comes on and it works.
I removed my door panels and reinstalled them, and this error is occurring. Weird
like it's not getting power unless the key is inserted.
Old 11-25-2019, 10:34 PM
Chad05TL's Avatar
disconnecting the battery and reconnect fixed my issue.
403 UA6
02-28-2011 06:43 AM
ardent_guy
11-11-2008 11:15 PM
Yui
1G TSX Problems & Fixes
03-11-2006 10:11 PM
mj31
03-11-2005 09:54 AM
VC Slim
02-23-2005 10:00 PM
Quick Reply: Memo button not working -> cannot store new memory seat
