Alarm siren location?...
Old Jun 22, 2006 | 08:02 PM
BrandonClaps's Avatar
Where are you guys mounting or have yours mounted? I'm installing mine this weekend.
Old Jun 22, 2006 | 08:43 PM
zax123's Avatar
Team Anthracite Member
I'll describe where I put mine. Well... if you have the hood open and the battery is on your right side, I put the siren on exactly the opposite side. There's a tiny bit of room there. Well, enough for a siren... I've had both a Compustar and a Viper siren there and they both fit.
Good luck!
Old Jun 22, 2006 | 10:38 PM
Good luck!
ok cool, where did u run the wire through the firewall?
Old Jun 23, 2006 | 02:23 PM
Old Jun 23, 2006 | 02:24 PM
zax123's Avatar
Oh, sorry. Uhm.. I found some wires that were headed through the firewall and followed them. When I recently did my sound system install, I found a rubber plug that was easily removed and left a nice big hole in the firewall. Either place works. It was just above the gas pedal.
Edit. The one I used for the siren was above the gas pedal. The one I used for the power cables for sound system was above and to the right of the gas pedal behind the center console.
Old Jun 23, 2006 | 03:23 PM
thanks
for the tach, did u grab it through the databus or at the injector?
Old Jun 23, 2006 | 03:25 PM
zax123's Avatar
Because I didn't know I could grab it at the tach, I grabbed it at the engine, but if I were to do it again I'd go for databus.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
