Aftermarket sub install... issues
Old 12-05-2013 | 03:34 PM
515kbpUA7's Avatar
08 CBP TL-S
i have a 08 TL-S and im in the process of installing a kicker 750w amp with a kicker comp 10in sub. this setup came out of my civic and worked perfectly!!! i purchased a line out converter and unplugged the factory sub and ran the LOC to those wires. amp gets power, and the sub plays.... but very very quietly. now if i turn the bass or gain up above half way the sub just goes haywire and plays 1 tone as hard as it can... this happen to anyone else? what would cause it to do this? what can i do to fix it??
Old 12-05-2013 | 06:42 PM
yungd's Avatar
You have to disconnect the active noise canceling system. It's under one of the dome lights. If I remember correctly it the rear dome lights.
Old 12-05-2013 | 09:39 PM
MarcoNorthPolo's Avatar
KCCO
^ What he said. Take off your interior light in the backseat, there's a wire you need to disconnect to get rid of the active noise cancelling feature. I'm 90% sure that's what causing your issue. Bear in mind that by doing so, you could get more road noise when you're driving, although some people have said that they couldn't tell the difference.
Old 12-06-2013 | 09:50 AM
515kbpUA7's Avatar
08 CBP TL-S
oops.. forgot to mention that i did that a while ago.. actually helps with the factory sub!!. anywho.. i figured it out.. poor connection from the speaker wire to the sub box.. now its beatin down da block!!
Old 12-07-2013 | 12:29 AM
KCCO
Happy you got it fixed.
515kbpUA7 (12-07-2013)
carz0159
09-20-2015 07:11 PM
Silverstead1
09-17-2015 07:45 AM
christopher1
3G MDX (2014-2020)
09-10-2015 07:43 PM
ellisd03tls
09-08-2015 05:17 PM
trinikidcl
09-04-2015 01:56 AM
