Aftermarket Amp question
Old Apr 22, 2005 | 03:49 PM
tunes2468's Avatar
6th Gear
I installed a hifonics brutus 1500 amp recenlty and for some reason it just does not sound right. I have checked everything and it all looks good. My question is this. Does it matter if i install the RCA's before or after the factory amp. Im wondering if the factory amp could be messing up my sound quality of my aftermarket amp. Kind of like a "your only as stong as your weekest link". Also does anyone use hifonic amps. If so do they sound ok for you?
Old Apr 26, 2005 | 03:26 AM
mikeyalvz04tl's Avatar
u dont need to use rcas in the tl use the hi lo input on the amp and wire it to the factory sub.
Old Apr 26, 2005 | 08:00 AM
rickneuropa's Avatar
Yes, you do need to take the inputs from before the factory amp for a clean signal. Are you using this amp to drive a sub?
If you are, make sure your using the low pass filter, and set it to 80hz or lower.
AndrewS
19
Mar 14, 2024 06:59 PM
Pegon95
Sep 15, 2015 01:54 PM
datadr
Sep 12, 2015 09:12 PM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
trinikidcl
Sep 4, 2015 12:56 AM
