after market alarm with remote start for 6 sp.
what do you guys think? you think it's a good idea to put a remote start on a 6 sp manual? all my friends said no.
So, I've always heard no as well....
https://acurazine.com/forums/showthr...remote+starter
For your review.....in case you wanted more info.....
Team Anthracite Member
gochan,
I've had remote starters on all my MT cars for years. The remote starters have all kinds of failsafes to prevent the car from starting with the car in gear. The most obvious of these failsafes is that the car is RUNNING when you get out of the car and arm the alarm. If the car was in gear, you wouldn't be able to get out of the car. Opening any doors or pressing the brake will not allow the car to start remotely anymore.
I have ordered and will be installing an alarm system/remote starter on my car this weekend. I ordered the Compustar 2WSS. It's a two-way system with a 1.5 mile range on the remote. It's a full-featured alarm system and has AUX channels to be able to control the windows from the remote control. It's going to be a very involved install, but it should be fun.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Zax
Zax
Ex-Acura Service Manager
They have all sorts of failsafes to keep the car from starting in gear, until someone defeats them, that is. I had a Civic owner come in one night to test drive an Integra. he told the salesman not to touch the remote because it was a remote start, but he forgot.
The car started, rolled across the parking lot & hit one of our new cars. Not only did the guy not buy a car, we had to fix both cars on our dime.
can you guess what my suggestion is?
I'm betting that the Civic owner had an automatic transmission remote starter installed in his manual transmission car and wasn't obeying the failsafes. Of course you can hack away at a system to "break" it, but if you install a proper MT remote starter, it cannot be started remotely if the car is in gear. I'm guessing it would be possible to leave an automatic transmission car in drive and remotely start it if you bypassed whatever checks there were at installation time, but why would you do that?
What I meant was that any system can be bypassed. Even the system that "holds" your key when the car is in gear.
All I know is every shop I called back when I was in college advised against installing them - and they even sold the kits for the manuals! I'm sure improvements have been made to the kits in the last 8 years or so.....but you still have to leave your car out of gear and rely upon your handbrake......and the last few cars I've had, the handbrake wasn't always the most trustworthy bit of equipment on my car.
Boom goes the Dynamite
There is no failsafe method for putting a remote start sysytem on a MT car. Could you live with yourself if you hurt someone after remote starting your car and it ran them over?
04 TL 6MT NAVI ABP/Q
Did you read the thread above? Several people pointed out that if you get the right system, especially on a newer MT, there are wires that can be hooked up so the car CANNOT be remote started if its in gear.
They actually have mercury switches for MTs. My best man in my wedding is the owner/installer at a reputable shop. I actually watched him install and demo the switches in a Z06 Corvette. Yes it is possible to do it right. either way, its your choice. Try leaving your car in Neutral b/f you get it. See how many times you leave it in drive. Me NEVER. I've had it on my 5.0 mustang and my Accord. I will be getting it for my TL. Just make sure your parking brake works well. Learned that on the 5.0. You just have to be conscious of what you are doing... Best of luck in whatever you decide.
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
i rarely leave my car in gear after i aprk. i don't park on hills so i have noreason to leave it in gear. and i wouldn't remote start my car everytime, it's for winter time in the morning when i get ready for work. so i dont'have to run outside adn leave my running car unattended, i'm not really doing it for show and laziness.
I have the Viper 791XV which is still top of the line responder.. I have it doing everything on my 6MT including remotely opening closing windows, trunk, and arming sensors all around the car. But the shop that installed all this for me says it is ILLEGAL to have a remote starter on an MT.. so warranty does not apply..
I went to another shop and asked if they can secretly do it for me even if I pay a little extra cash (under the table) .. they said no can't risk the liability.. and again said it's illegal..
I've went to about 3 shops that install car alarms / stereos.. and none of them will add it on for me.
What LAW states that it is illegal to have a remote starter in MT? Can someone point to the section/paragrah from a goverment site of this article? or were these installers blowing smoke up my ass?
It makes no sense that it would be illegal if the remote start will only work when the clutch is in neutral; otherwise ignoring the command from the remote if it is in gear... it sounds easily logical...
Can some one tell me where I can go in the Bay Area, CA to have them add the remote start with the neutral check in place for my TL? And how much? I know it's normally about $80 for labor and small parts if I had an automatic TL.
Starters like the Compustar that zax123 mentioned can be safely installed on a MT car. In my opinion, those who are doubting likely don't know enough about the topic to be giving advice on it.
Starters can be dangerous if, for example, a system that was designed for an automatic trans car is used on a manual - but systems like the compustar are well designed for manuals and use simple logic routines to make sure that the car isn't started in gear.
TL-SHAWD 6MT Rocks!
gochan,
Zax
Zax
Compustar is very good.
I asked Compustar for an installer they recommended in my area, and I went there. $600 installed.
oyayjoe
09-12-2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
