Added amp and subs problem. Need advice!
Old Sep 23, 2012 | 12:45 PM
bignutz's Avatar
I have just added an amp and sub to my factory 08 TL-S. what I have b
Done is ran my power wire from battery to amp, ground off the same screw as fuel pump ground, remote off #32 fuse, and disconnected the factory sub and hook a converter to the wires so I can use the audio cables.
Now here's my problem. When I start the car I get constant bass through. The subs, but when I open the door it stops. When the acc is on but car not running it works great. I tried to tap to another fuse but still does the same thing. The only timeout acts like this is when the car is running and the door is shut. Can anyone help.
Old Sep 23, 2012 | 06:28 PM
BlitzBlackGSXR's Avatar
Did you disconnect the noise canceling mic in the rear ?
Old Sep 24, 2012 | 12:59 AM
I hate cars's Avatar
Yup. Classic of ANC.
Old Sep 24, 2012 | 09:42 AM
bignutz's Avatar
No I did not. I did some research yesterday, and this is all I could find, so this sounds like it might be my problem, but not sure. Thought I would ask to see if anybody had a similar problem. Thanks.
Jul 16, 2017 07:33 AM
LoneRonin
Jan 4, 2016 01:03 AM
Froid
Sep 27, 2015 06:16 PM
rboller
Sep 23, 2015 02:49 PM
