Added amp and subs problem. Need advice!
I have just added an amp and sub to my factory 08 TL-S. what I have b
Done is ran my power wire from battery to amp, ground off the same screw as fuel pump ground, remote off #32 fuse, and disconnected the factory sub and hook a converter to the wires so I can use the audio cables.
Now here's my problem. When I start the car I get constant bass through. The subs, but when I open the door it stops. When the acc is on but car not running it works great. I tried to tap to another fuse but still does the same thing. The only timeout acts like this is when the car is running and the door is shut. Can anyone help.
bignutz (09-24-2012)
rboller
09-23-2015 02:49 PM
