Acura Music Link problems
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
The software doesn't work on the computer...it freezes at the last part before completing files it's supposed to put on the iPOD. Despite attempts including erasing the whole iPOD, reinstalling the software, I can't get it to work.
Anyone have any clue if it has worked for anyone? I am really disappointed. A headphone jack and power cord would work better. I can play the iPOD but I have no idea what song will play and have NO control over the iPOD, so it'd be better in the car with me than in the glovebox.
The car is incredible but I feel like I got taken on this one option.
iTunes was freezing on me as well. It happened when doing the voice files for the album names. I found that if I switched to the task manager and did a restart on the PC, iTunes would finish after. I chalked this up to the fact that I am using a 3G iPod, which is not on the compatibility list.
I mounted my iPod on the dash because of this. I usually listen in DISC 5 or DISC 6 mode, but when I want a particular album or song, I just unplug it and cue up what I want then plug it back in. I know this is not the greatest, but it works.
jjh1234
jjh1234
tuning / modding newbie.
jjh1234
jjh1234
DAMN YOU ACURA!!! LISTEN TO US! YOU EFFED UP BIGTIME ON THIS!!
...sorry for the rant... i was just so looking forward to this...
my drive+play may not be perfect, but for the cost and what it can do i think it works wonderfully.
Originally Posted by sequoia
I just can't justify spending 400 on a system that is no non-intuitive, just to ultimately mount my iPod on the OUTSIDE of the glove box or center arm rest... just to reach the songs I want...
and isnt the drive + play just a controller? you still need an aux in unit installed
thats like 300 in hardware alone before any installation
Even though the Music Link DOES SUCK in some respects, keep these things in mind.
1 - 100% plug & play install (no wires to cut)
2 - Won't void vehicle warranty
3 - Crystal clear sound
4 - At least SOME integration with factory radio and display
5 - Get to keep XM
6 - No guessing about vehicle compatibility
7 - Possibility of future updates
jjh1234
I did not spend $400. It cost me ~$250 parts and 3 hours of my time. The installation instructions from Acura are pretty good. My biggest problem was removing the darn aluminum strips on each side of the navi. The KTC Trim Tool kit probably would have helped.
5 - Get to keep XM
jjh1234
5 - Get to keep XM
jjh1234
and any pics of the install process?
Originally Posted by JustinZ
im going to be recieving my unit this week - any tips on the install? how did you end up getting the aluminum strips?
I made my own vent removal tool from a metal coat hangar bent into the shape of the tool listed in the Music Link Installation Instructions (see link below). You have to insert it like the instructions say and use a fair amount of pull to get the entire vent assembly to pop out.
The aluminum strips were a bit more tricky. Maybe somebody else has a better way. The hard part is releasing the two "retaining tabs" at the top of the strip. The installation instructions are not real clear about the placement of these, but Page 20-77 of the 2004 service manual gives a better picture (look for the "C" hooks). I used the plastic wedge that happened to come with my proclip ipod mount. I jammed it between the navi and the aluminum strip and pulled the strip away from the dash at the same time. It still took a lot of pressure and I was scared that the strip or the navi bezel was going to break. Eventually they released.
The rest of the install was by the instructions except that I mounted the iPod on the dash for reasons I explained earlier. Hope this helps.
https://acurazine.com/forums/showthread.php?t=127777
Mounting Photos
http://mysite.verizon.net/vzeefn0v/
I had two problems with the install. One, the vent removal tool and two, the aluminum trim.
Mounting Photos
Mounting Photos
wow, I thought it would be a lot easier
![what](https://acurazine.com/forums/images/smilies/what.gif)
I think I’m going to try and get the wire to the armrest - is it going to be long enough?
do you think ill have to take apart the glove compartment if i mount it in the armrest?
and would you happen to have a scan of the 2004 service manual? i just looked at my aluminum trim pieces and I have no idea how I’m getting those out - those air vents also look like a pretty daunting task too
Ill be damned if I pay somebody 200 bucks to do this
uh
Check your messages!
The cables are way long, so you should not have a problem putting it where you want. I did not remove the glove box or the panels on either side of the radio. I was able to squeeze it out between them.
The vent is not too bad. You just have to get that tool between where the two parts of the vent meet.
Start removing the trim pieces where they meet the arm rest and work your way forward. Use some kind of plastic tool or a screwdriver covered with electrical tape. You could always buy the KTC Tool Set here.
http://thetoolnetwork.com/panel_popp...l_company.html
Mike Bertram
09-10-2015 09:27 AM
nuldabz
09-03-2015 05:49 PM
