Active Noise Cancellation - Front
Old Mar 23, 2009 | 01:03 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Alright, I know how to unplug the ANC in the rear, and I know where the ANC is located in the front, but how do I get to the front ANC? The 3G Garage I-163 - Active Noise Cancellation link - https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-163-amp-sub-installed-08-tl-s-amp-not-getting-signal-when-doors-shut-700991/ includes a diagram, but no instructions on how to take apart the front domelight assembly. Help is appreciated.
TIA.
Old Mar 23, 2009 | 06:58 AM
LoveMyTL-S's Avatar
Perhaps this will help:
http://www.in.honda.com/Rjanisis/pubs/SB/B04-036.PDF
Old Mar 23, 2009 | 04:35 PM
Originally Posted by LoveMyTL-S
Got it!
Thanks!
That diagram, and the illustration in my first post helped me locate and unplug the ANC, finally!
Old Mar 26, 2009 | 12:50 AM
Nick337's Avatar
another alternative that i tried today was a fellow member told me to try this, pry up the center channel and unplug the box right there.
Old Mar 26, 2009 | 01:03 AM
Thanks, but without the center channel, my DVD-A's would go to waste. I upgraded all of my speakers, including the center channel. People say usually that they only needed to unplug the rear, but for me, unusually, the rear didn't make too much of a difference. The front definitely did.
Old Mar 26, 2009 | 01:19 AM
Nick337's Avatar
your not unplugging the center channel the box underneath it.
Old Mar 26, 2009 | 01:22 AM
I see. You know, I never even knew there was anything to do with the ANC under there.
Old Mar 26, 2009 | 09:05 AM
LoveMyTL-S's Avatar
Originally Posted by princelybug
Got it!
Thanks!
Your very welcome
Old Apr 3, 2009 | 12:12 AM
flappy188's Avatar
why do you want to disable this option?
Old Apr 3, 2009 | 01:16 AM
When you put in an aftermarket audio system with amps, the ANC is multiplied several times over the normal level, and is very annoying when you drive the car. It makes an obnoxiously loud "humming" noise unless you unplug it.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
