3sixty.2 >>>>> where to tap into remote turn on wire?
#81
wow, i feel like the BIGGEST idiot ever.
so I have got this sucker figured out finally. I cant believe I never checked my soldered connections. I checked every other damn connection there possibly was, but never unwrapped my soldered connections coming from the factory amp to speaker wire.
As I had just about given up and was about to cut the wires to take the signal before the amp, I decided "well check these connections here" (even though everyone in the world told me numerous times to check all connections. So I did, and decided one looked ehh... not great. so I cut it and put on some male and female connectors on each end for easy connecting/disconnecting while I figure all this out.
I did that on front left and rear left channels.
And now I am here to tell you not only to I have a better signal and even after the OEM setup the graphs are now "on the chart" and not well below it. All of the hiss is gone too. So there goes two issues at once!
Also, during the OEM setup after doing this I actually got my first red "clip" signal!!! on the front channel, and have a blue led signal on the rear. (I am now tempted to cut all solder joints and replace with the male/female connectors to see if I can get the rear channel to show a red clip light).
anyways, a HUGE THANKS to everyone that has offered tips, etc... and been a part of numerous threads on different boards. I really appreciate it, and yes should have checked those connections a long time ago.
Thanks again everyone.
Now comes the rest of the adventure. Setting the gains, EQ, etc...
but atleast now I am in a much better place.
#83
[QUOTE=Theguywhostoleurfood;12761665]That's the thing, the only connection I see is the gray one at the bottom of the amp, unless I'm blind and there are ones coming into the top, making the bottom ones the leaving ones?[/QU
i don't remember exactly what color the connector is, or another way to do this would be to pin factory speakers directly going to the back. meaning to cut the wires at the speaker and take those wires and run them to the back for the 3sixty.2
#84
I kinda knew it was your input wires from the get go. Not soo hard to troubleshoot it man, i told you that thing is very easy to hookup. Solder if done properly will take all the worries out of those crimp connections. I posted in your thread you have in DIYMA also. Lemme know how the rest of your install turns out.
like I said.... yes I screwed up by not checking my solder connections. I soldered them all from the get go... but one of them was not that great and turns out it was the culprit.....
I never argued to anyone that it was not easy to hook up, i just simply posted my troubles.
and yes, I knew once I posted my mistake/correction I would get burnt for it.... so thank you.
#86
for the most part things are headed in the right direction. now its just setting the gains appropriately, the EQ, time alignment, etc... (a buddy of mine is sales mgr at a nice shop and I think they have a RTA, going to see if I can get an hour or so with that).
#88
yes all fade and balance are centered.
I adjusted the level on the 3sixty to even out the sound. My left side is at -9db and right side is at -3db and its nice and even.
I assume they should be similar in levels, not sure why I am getting unbalanced levels.
#91
true, I know its possible. but this amp is less than 2 weeks old. I may pop my PC2150 back in just for fun and see what happens.
#92
I am also about to order a new pair of tweeters to try out, not that there is anything wrong with the ones I have now. I actually just got dont trimming out the factory tweeter housing and the casing to these tweets to drop in and keep the factory look. They turned out great.
#94
well after many many MANY attempts and trouble shooting, I have finally got it completely fixed up!!!!! I am super excited.
and numerous times I declared myself an idiot for not seeing/finding different little things that made a huge difference.
like Nick337 said early on..... check your connections folks if you are having poor quality results. I found yet another "dumb" thing I had that didnt think anything about that was causing a LOT of issues for tuning/setup.
I had all my wires soldered like they should, but my dumbass when putting the heat shrink tube over the solder joints, put two in one. For instance the left rear pos and neg in one heat shrink tube. well today after yet a couple more annoying speed bumps I was messing with them and as I grabbed them and applied pressure I could hear a difference. I then had one of those "aha" moments and was like I am an idiot.... the solder joints are in one tube and causing the signal to bounce off each other, etc....
anyways... problem solved and ran setup again, everything came out as it should have 12342 attempts ago. I got the crossovers all set, played with the eq, but more importantly sat there and jammed some tunes with a huge smile on my face that its all finally right. Now I can focus on a amp rack/floor box. I want to put an amp rack where the spare tire is so when you lift up the factory flooring you see my 3sixty and amp. So now to attempt my first floor/amp rack.
thanks for everyones help along the way.
#96
what is yours going to be/look like? the entire floor, or tire area like I am trying to do?
you getting the cuts done for you? I will probably make a couple screwed up cuts in the process as well.
and yes, its sounding GREAT! just a little eq tweaking along the way and all is good.
#99
I originally wanted to run two 3sixty.2 because I was short on outputs because the the 3sixty.2 couldn't do a 3way active plus sub configuration. So i ordered another one to have my DSP on a couple of more channels. Then i found out that you can tune both of the 3sixty.2's at the same time. So I sound the brand new Sixty for what i paid for it plus the warranty. Now the bitone.1 does my 3 way front and components in the rear for rearfill. Now all the 3sixty.2 is good for is jus there for my 13.5 in the back.
#101
its coming. I have not had another day off to really do much more. Last thing I did was take out the spare tire and build a floor to house the amp and 3sixty.2 under the factory floor cover. Now I just need to clean up the wiring some more and build a cover with a plexi window, then its on to sub woofer enclosure. I would like to have the sub enclosure all built and ready to drop the subs in when available (which looks like it could be a while unfortunately).
#102
#103
that's cool.
I am kinda weiry about not having a spare tire.... but at the same time taking out a box/amp rack to get to the tire would be a pain in the ass as well on the side of the road.
In my Maxima I took out the spare tire and was fine..... just better re up my AAA hahaha
#104
that's cool.
#106
I'd rather be golfing
Question for you with this method of using the jumper in the 360... did you keep the factory amp or not? I had mine installed MINUS the factory amp and I have the turn-on problem. Not sure if the factory amp ups the voltage to the 360? Also, for anyone who has this install, can you tell me where you grounded your amps? I've got altenator whine and I would like to start at a place where others have had luck. Mine's an '06 TL non-nav. Thanks
#107
I did not take out the factory amp. I did switch the jumper on the 3sixty to send the remote wire turn on OUT of the 3sixty to turn my amps on and the 3sixty turns on from the input signal coming from the amp. I have the signal coming from the factory amp (the large gray connector) and then converted it to RCA and used those inputs on the 3sixty.
As for alt whine, I have none at all.
#108
cjj, where did you ground too? Did you use that pre-existing screw in the trunk under the tire? I'm also interested in hearing about what others have done from a settings perspective. Specifically the xover type, frequency and slopes used. Also, has anyone tweaked the delay at all? I guess I could do a search on 360.2 settings
#109
I used the bolt that is at the far end of the trunk almost against the back seat. going to try and find a different place though.
as for settings, I am currently only running a front 2 way setup. I have my mids high passed at 60hz and low passed at 2k and my tweets high passed at 3k on a 24db slope, mids on a 18db slope.
#110
#111
I just finished my install this weekend. I took a different route with my ground. I used a pre-existing hole in one of the down/crossmembers behind the seat, filed all paint away and then used a JL grounding lug and grounded all amps and 360.2 to it. Worked like a charm. Not a hint whatsoever of alt noise with lights, AC, and everything else turned on.
I gotta be honest. Didn't really realize what a mammoth job the install is. One thing I've noticed is that with the new system, you really hear the difference with your side being louder, whether in driver or passenger seat. I can compensate by balancing a little to the other side and I know I can adjust the level via the 360.2, but it sure leaves your passenger hating the sound if you have someone in the car. One thing I did that I wish I had done differently is aftermarket amp the center instead of using the stock amp. I feel like that would have rounded out the front sound stage a little more.
rockyboy
08-04-2024 10:35 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
