3sixty.2 >>>>> where to tap into remote turn on wire?
I have all my stuff ran and wired up, just curious where to tap the remote turn on into?
I have read many threads that say the factory one is too low voltage. Has anyone had success with this that can help?
thanks in advance.
Cory
thanks in advance.
Cory
Here's what I found, when I installed mine:
You don't need to hook-up a remote turn-on wire for the 3.Sixty, it has a feature that will sense a low current signal from the speaker input, and automatically turn the unit on. You can also set a jumper pin (inside the unit) to have the 3.Sixty send an output voltage to turn on your amplifiers. Instead of using the remote lead wire for the input to the 3.Sixty, you use it as an output turn-on lead for you amp(s). It's brilliant!
Have a look:
http://www.rockfordfosgate.com/scrip...ted=1145649861
Have a look:
JimmyDee..... thanks for the tip and link, it worked great!
I am just now in the setup/tune stage. However I have a problem. I have no sound out of the right channels....
I have 2 amps hooked up, one for my tweets, and one for my mids. I find it odd that neither are producing sound in the right channel.
I also have some annoying hissing going on.
I have not trouble shot anything yet as I have not had much time to work on it. All i have right now is everything wired up, I havent put any of the car back together so I can still easily access all wiring, etc... so I will have to tackle this later this week. But if anyone has any ideas they want to throw past me go for it!
Down for a photoshoot?
Heey, I just recently got my 3sixty.2 as well, and I'm also in the process of fine-tuning it myself. I got some advice from member, fourthmeal, stating that the internal gains controlled via the 3sixty software has to be adjusted to produce minimal "hiss" from the processor, after which you can adjust the amp gains to compensate.
Regarding the right channels not working ... not entirely sure what's wrong with that ... perhaps you can check the input signal connections again, and play with the software to see if anything makes a difference ...
as for the input levels. when I was setting the 3sixty up I was not able to get the input level led's to turn red. they would come on and turn blue, but even turned all the way they never turned red. the manual says to turn it until its almost red. either way I think i have them too high and that is part of my hissing problem.
as for the channels, I have not had time to dig into it yet. I hope to this week though.
Actually 75% (3/4) of max volume, which is 40 on the 3G TL stock headunit so 30 is the ideal volume to set it at (or if you have an oscilloscope you can figure out what the clipping point of the stock headunit is). Anyways, at that level, you should be able to get the signal high enough to get a blinking red light for the clip indicator
i will re do the setup and do it at 75% volume and see what happens.
I still have not figured out why I only have audio on the left channels....
If you were setting it up at full volume, then you were surely clipping the headunit ... not entirely sure what that translates to with regards to the 3sixty clip indicators, but surely redo-ing it with 75% volume would be worth trying ...
As for audio only on left channel ... perhaps the left channels are blown??? Try hooking up the left speakers to the right channels to see if the speakers play fine ... perhaps also check balance/fader on the stock headunit to see that it's not set to the extreme right (just in case haha)
Consider checking whether it's a problem with the 3sixty (disconnect RCAs from the 3sixty and perhaps take an AUX to RCA line and connect directly to an mp3 player to see if the left channels play then) or whether it's an issue with the amp, speakers ... or perhaps even some faulty RCAs (possible I guess??) Try switching out RCAs between left and right channels as well ...
I have trouble shot the hell out of this thing.
I am about to run a new speaker wire to my front right tweeter cause no matter which way I slice and dice it, I am getting nothing out of it.
After that I am having the biggest PITA getting the thing setup right. I have tried every setup option there is and tried summing the inputs and not summing the inputs. I am getting horrible levels, static, etc.... and quite honestly it sounds like shit.
I have tried different RCA's etc.... I think one of my amps may have a bad channel or may be going out. I am ready to take it to a RF tech and see what they can do.
oh well.... i will get it eventually. just annoyed cause I dont have the time to spend a full day on it as I am working my ass off right now too.
Also am about to pull the trigger on a JL HD900/5....
I use this same one for all remote wires. The wiring diagram should specify this.. you can daisy chain as many remote wires together as you want.
http://.com/4zlfg59
well I think one of my amps is kinda fucked.... after testing out all kinds of scenarios I have come to the fact that one of my amps is part of the problem.
which just means I am about to purchase my new amp I had planned on getting all along a lot sooner. I am going to pick up a JL HD900/5 tomorrow and take place of both amps. getting a nice deal on the amp. brand new from auth. shop for $650.
This is getting VERY annoying!
So after getting the new JL amp and taking out my PPI's I got everything in and tested out.... found that I had a short in my front mid. Actually for some reason the terminal was close enough to the metal of the door it was causing it to go in and out. So I had to shave the opening a little more.
Got all that done, swapped out my tweeters to a pair of Peerless tweeters cause one of my MB's were bad.
So I finally have tunes out of all 4 speakers! YES! So I go to the back unplug my RCA's and power/ground.... then I secure the amp and 3sixty to the floor temporarily until I build an encloser/wall for them. Plug it all back in and now I am only getting sound out of one channel!!!!
what the hell is going on here. If I swap the left and right of the rca's the sound swaps as well, but now I am still only getting tunes out of one side.
I am extremely frustrated now......
I know that this forum is kinda on a different topic, dealing with the 3sixty processor. But I was wondering if anyone could help me out, as to, where exactly I should be splicing the wires-around the stock amp. And which wires belong to which signal(speaker). Is there a diagram with that information?... If anyone could help-Id greatly appreciate it. Thanks in Advance, Yall.
here's the thread I used to determine the wires at the amp, etc...
https://acurazine.com/forums/showthr...p+wire+diagram
Thanks... That's exactly what I needed And if yall wouldn't mind answering another question. From opinion, on a scale from 1 to 10 , what would y'all rate the 3 sixty processor? Cause I'm still in process of purchasing one, and don't want to purchase something that Ive seen mix reviews for, but at the same time don't wana Bank on a processor.
Anything input would be greatly appreciated.
I have just had trouble getting it all setup right. once I get it working correct I will post a review for you.
Ya a 7 just might be good enough for me. Thanks for the quick reply. I looked into the Bit one, and ya, that isn't really in my price range-even though I don't doubt it preforms alot better I guess Ill just have to put the time into tuning the system with the 3sixty, that's all. I read and saw online that the 3sixty 3 is coming out in July but will also be 600, where as I should be able to find a version 2 for under 300-right now( in good quality) I can always upgrade in the future...
