3Sixty.2 install question(s)
2012 SH-AWD / Advanced
I've read some conflicting posts on this, and wanted to clarify how others have their 3sixty.2 wired. For the B+ input, should that be wired to a 12v source (always on), or set up as a remote on?
I plan on using the remote jack on the 3sixty as a 12v output to the (aftermarket) amp, therefore using the signal sense circuit to turn it on.
If wired to a constant 12v source, where are you getting this from, and are you fusing your power wire?
Thanks in advance.
Thanks in advance.
Retired!!! ON TOP!!!
the B+ should be a COnstant HOT 12V source... directly from your batttery... where you get it from is relative to where you're installing the 3sixty.2.... if it's in the trunk near your amplifiers... then just tap into your power wires heading toward your amps...
Great, thanks. I went to RF's troubleshooting guide online, and it stated: "Also, the manual incorrectly states that the B+ connector on the 3Sixty and Remote should be connected to a switched 12V source. It should state that the B+ should be connected to a constant 12V source instead."
Skirmich
09-15-2015 06:41 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
