2013 Navigation Disk / Honda Splash Screen
Greetings my brothas!
Since i bought my used 06 TL the navigation splash screen said honda. My navigation also did need speak to me. It would lower the music and try to speak but nothing came out (yes the voice was turned up), and i was missing a few other features like adjusting the clock on the dash.
So, i was hoping that buying a 2013 dvd would convert everything back to acura, and i would have all of the acura settings, but unfortunately it did not.
I was able to update my maps, and i did gain voice directions, but thats about it.
I read all of the threads regarding this issue. i have tried to put the dvd in my computer, copy the acura bin files, ect....but my laptop will not read the dvd at all. that was actually i good thing for me because i then noticed those instructions were for a different version (years) dvd.
anyone know how to get me back to acura settings with the new 2013 dvd?
how do i do a hard reset?
Head a da Family
This happened to me once upon a time and the stealership had to reset the entire Nav system. The one good thing that it had was the Accord's instantaneous MPG gauge on the screen as part of the Trip Computer.
To this day, I cannot understand why Acura didn't give us an instantaneous MPG gauge in this day & age of fluctuating gas prices.
Finally figured it out!!!
had to follow those instructions, minus the honda conversion parts and skip to the acura converstion parts.
it didnt mention this, but you have to reverse rename the files, so the navi system thinks all the right files were available.
If anyone has any questions bump this thread or PM me.
Okay----Here are the details to try this. Again...DO THIS AT YOUR OWN RISK.
Step 1)
Remove DVD disk from Nav system in trunk. Key must be in II position or III position. Press eject
Step 2)
Copy the following files to your hard disk. You must have a DVD Reader.
File1=BN2HH12C.bin
File2=BN2HH110.bin
File3=BN2HH120.bin
File4=BN2HHmld.bin
File5=BN2HN12b.bin
File6=BN2HN18b.bin
Step 3)
Take File #3 above (BN2HH120.bin) You need to rename this file to BN2HH12c.bin, and burn a CD. So, your CD should have the files named in Step 2, but BN2HH12C.bin should "REALLY" be the file BN2HH120.bin (But named BN2HH12c.bin)
Basically, the system is looking to load file name BN2HH12c.bin. We are tricking it into loading BN2HH120.bin by renaming it. BN2HH120 is really the accord nav system.
Burn a CD (Yes...it doesnt have to be a DVD) with these files and place into NAV system.
Step 4) Get into DIAGNOSTIC mode by holding down "MAP/GUIDE+MENU+CANCEL" until the diag screen shows
Step 5) Select "Version" from the diag screen
Step 6) Select "DISK LOAD" which appears in red.
Step 7) DO NOT SHUT OFF KEY from II or III postion
Step 8) It should re-boot, and you will see the HONDA logo instead of the ACURA logo. Place the orig NAV disk in the NAV system
YOU NOW HAVE A MUCH BETTER TRIP COMPUTER!!!! (Than in the MID)
To go back to the orig Acura system, make another disk, however....this time, Rename the Original BN2HH12C.bin file to BN2HH120.bin. The nav system with the Honda logo is now looking for BN2HH120.bin If you re-name the orig acura file (BN2HH12C.bin--->bn2HH120.bin), you will go back to normal. Follow the same proceedure as shown above, only with the disk described here.
I have two disks, and when I go to get an oil change, I will reset to ACURA....
AGAIN....THIS IS AT YOUR OWN RISK!!!
Step 1)
Step 2)
File1=BN2HH12C.bin
File2=BN2HH110.bin
File3=BN2HH120.bin
File4=BN2HHmld.bin
File5=BN2HN12b.bin
File6=BN2HN18b.bin
Step 3)
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
02-26-2016 03:44 PM
rockyboy
01-25-2016 06:00 PM
travr6
09-06-2015 02:11 PM
